GE GSS25JFM Side by Side Refrigerator
Problem for GE GSS25JFM Side by Side Refrigerator
GSH22SXA & several problems
By rebek95 on Oct 03, 2009
We have had this side by side just a few days over a year now. On the freezer side ice can coat the sides and back. Food is so covered with ice you can't read the writing on our packages. I think we are getting a thaw in between times that alternates with the frost. Sometimes the freezer is dripping water from thaw, and then comes the frost. Even if the freezer is set at 7 or 8 it will have a thaw at times. Icecubes don't stay separate, but also seem to experience these fluctuations. The cubes then mold to the plastic thingey that pushes the cubes out, so no cubes can come out and the motor stops working. We have to remove the ice tray and let it thaw to get the ice out. Other times so many ice cubes come out it the ice tray jams in and we can't remove it and of course then the ice cube dispenser won't work. What a bummer, my first side by side that I saved up for and I don't have the money for a repair man.
Comments:
Oct 03, 2009
- I've already checked. The dispenser closes very well, something else is going on
Oct 03, 2009
- Door seals are fine. Sorry I forgot the J. When I take the number from the metal plate on the upper side of the refrigerator the model number is listed as GSH22JSXA Its stainless steel, so ends with another set of SS.
Oct 03, 2009
- This is the refrigerator I have http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GSH22JSXSS
Oct 04, 2009
- I don't see the information you are speaking of. The same answer as yesterday LOL. I'll be gone for the rest of the day today but will check back when home again. Thanks for any help you can give me.
Oct 04, 2009
- Now I can't seem to add comments to the post???
Oct 04, 2009
- My comments also disappear after posting
Clarification Request
Posted by Sea Breeze on Oct 03, 2009
Well Rebek95 If you think you can work with me and know how to do some things with diagnostics or know someone that can help you, I will be able to help you. First I would like you to double check your model number as I am un able to locate a GSH22SXA However I do show these model numbers GSH22SGPASS GSH22SGPBSS GSH22SGPCSS GSH22SGPDSS GSH22SGRBSS GSH22SGRESS
Let me know what you find because answering your question correctly depends on the correct model, Thanks Sea Breeze
Best Solution
posted on Oct 04, 2009
Very Helpful)
Sea Breeze
Rank: Guru  GE Refrigerators  Expert
Rating: 90%, 740 votes
For some reason my post has disappeared. I left you with a lot of information and now All I have is a clarification request. Something is going on with the server here today.Sea Breeze
Comments:
Oct 04, 2009
- Let me know if you received the information, Sorry I just am a little confused here as to where all my response went. If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
Sea Breeze Parts and Technical Services
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Click here=> PROFILE ARTICA REPAIR MANUAL
Oct 04, 2009
- Here is basically what will need to be done in the attached PDF. Different model number than yours but same parts and procedures except I will add two sites I want you to read because your defrost drain appears to be blocked also. A freezer is the best dehumidifier there is. There should not be ice clinging anywhere but the rear panel. Thanks, Sea Breeze Click these links about defrost freezing drain repair and I will be here when you return. Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER Here=> http://servicepartstec.blogspot.com/ Here=> http://appliancepartsse.blogspot.com and here below=> SEA BREEZE TIP's and here=> http://appliancepartsseabreeze.com/APPLIANCE%20PARTS%20SEA%20BREEZE/seabreezeapplianceparts%20default.html
Oct 04, 2009
- Most likely part number WR51X10101 Defrost Heater has burned out. Unplug and remove the rear panel inside the freezer. Defrost with a hair dryer and examine the defrost heater and look to see if burned out, It has a glass tube around the heater element and will be easy to see if burned out. If you need to replace the defrost heater you should also replace the defrost thermostat part number WR50X10054 If you don't see a problem with the defrost heater and I will instruct you on how to manually defrost to test the heater and defrost thermostat. Check for bad connections on wiring to heater and defrost thermostat. Your model has a mother control board part number WR55X10942 We may also need to check that because it does the thinking and determines the time for defrost. Let me Know what you find, Thanks, Sea Breeze
And a service manual that has a lot o similar information to assist you in your repair Click here=> PROFILE ARTICA REPAIR MANUAL
And the location on the board to cause a test of the defrost circuit.
Oct 07, 2009
- Go to page 7 in the PDF Manual of the refrigerator you have from the web page you sent me http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GSH22JSXSS I downloaded the manual from that page and attached it to this email. The instructions are on page 7. You can unplug the refrigerator if you like, but the water should not come on unless you should press the door switch in and pressed the dispenser control while the power is on. Buy your new filter and be ready to follow the directions in the manual. The drain hole in the fresh food compartment should have nothing to do with any blockage unless the water enters that area during defrost and that drain opening also had a blockage. When you place the new filter inside the holder you do need to fill the filter body and new filter with water to prevent air from being in the filter and causing air to be trapped inside and would cause a longer purge of the water just to get the air out. Sea Breeze
Oct 07, 2009
- Yes, the hole in bottom and back of freezer should not have ice or water sitting there in the opening. And as I keep reading I get clues that the ice maker is over filling I think you mean to say and then a long thaw? If a compressor stops running because the condenser fan below the refrigerator will stop cooling and a drastic change in temperatures in the fresh food section and the freezer will begin to take place. I have heard of the defrost thermostat sticking and the defrost heater remains on too long to the point of almost melting the back wall. and defrosting the food near the back. Also your model has an electronic ice maker and sometimes they start telling the water control valve to open when it should not. Also the possibility of a leak in the dual water control valve and the fill tube is overfilling the ice maker and all the extra water remains in side the freezer. I need you to get me the temperature readings from inside the freezer and fresh food sections. Look close to where the moisture is coming into the freezer. If the drain is clear and the back panels don't have ice build up then the defrost is OK. Also Milton I think was trying to say look for warm moist air being drawn into the freezer. That can happen if the defrost element under the Ice Maker remains on. It also will tell the water control valve to come on and overflow the ice maker.The dispenser chute door is stuck open or seals around the door are bad and air has no choice but to be drawn in. Your main board knows how may times a day the door has been opened and adjust the defrost time to the run time of the compressor. Something simple like a light staying on in the freezer or fresh food section will change run and defrost times and keep the compressor running. The the damper door between the freezer and the refrigerator gets stuck open or closed and sometime they are electrically controlled. So get me the temp readings for both sides. Not what the display says I need thermometers. Defrost condensate collection pan under the freezer should show some water after a defrost. Pour some water into the freezer hole and see if it ends up in the pan below the refrigerator where it's returned to the air inside your home.
Sea Breeze
Oct 08, 2009
- He needs to check the defrost heater first. If defective replace the defrost heater and the defrost thermostat. He should not tell you first to replace the circuit board first because that is a costly scam! And while the back is open you should ask to pour some hot water and Clorox mixed into the defrost drain to kill the algae and scum that collects over a period of time. This will also tell you if the defrost drain is working properly and will help remove any accumulated trash in the line. Remember the manual I sent you covers a broad range of models not just you specific model. If You want to see a break down of your model click Here=> GSH22SXA There are 6 model that GE provides similar model numbers for, just chose one. They are basically the same and I don't know for sure how you got the XA suffix will need to ask GE about That, Good Luck and Thanks, Sea Breeze
Oct 08, 2009
- OH dont forget to put your model number into the model search box and click find. Sea Breeze
Oct 08, 2009
- The model number GSH22JSXA we have change the number around so many times I'm confused. Sea Breeze
Oct 12, 2009
- Thanks For The Rate Rebek95! If you ever need me again feel free to let me know, Sea Breeze
Nov 15, 2009
- How is Rebek95 Refrigerator doing? Sea Breeze
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Sea Breeze is amazing ; ) I have a great basis of information when the service man arrives next week. Thank U!! " - rebek95
Solution #2
posted on Oct 03, 2009
Not Helpful)
milten1
Rating: 90%, 492 votes
check the ice flap on the freezer door it sounds like it is sticking open and letting hot air in
Comments:
Oct 03, 2009
- have you checked all your door seals
the only way you get frost is air
Was this helpful?
Yes
No
Popular Solutions for GE GSS25JFM Side by Side
Questions and Unsolved Problems for GE GSS25JFM Side by Side
Do you recommend GE GSS25JFM Side by Side Refrigerator?
Answer
Answer
fan noise in ge frig gsh25kgmbww fan in freezer making loud whirring noise
Answer
my side by side makes a noise and runs all the time. the noise comes from the area of the ice maker.... (More)
Answer
i have side by side freezer side freezes up on the back side of freezer dosent keep frozen the... (More)
Answer
The left side, the freezer, of the side-by-side has failed to stay frozen on two different... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerators Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
