Question about Kenmore 73952 Gas Dryer
Model 110.74852400. How do i get to the coils to
Model 110.74852400. How do i get to the coils to replace them?
Just changed the coils on the same dryer 110.74852400 but problem not fixed...flame burns for 30 seconds and shuts off...relights in about a minute, than burns 30 seconds, shuts off...any advice??
Posted on Jan 14, 2010
I have the older model which has the 3 bolt ignition coil. If I replace the coil, does the new ignition coil have to be 3 bolt as well? the 3 bolt replacement coils are so much more expensive
Coils are usually engine specific, the number of bolts does not determine whether or not it will work. If you really want your chainsaw to work correctly - buy the right part. It's a cheaper than a new one! Using the model number you supplied, I found them for under $50, which is about the value of an old 050 Stihl -wow, that's a heavy old saw. If you are still (Stihl ;^ )) not sure, call a Stihl repair facility. There may be an old timer mechanic who knows.
Oct 19, 2015 | Stihl Ignition Module Coil 050, 051, 076,...
Engine stop
If theres no spark from the spark plugs then you would have to replace them?
Jul 12, 2008 | 1993 Toyota Corolla
Why wont my saw fire the sparkplug with the replacement coil
Make sure you are using a resistor plug. This is extremely important on this model. If this is not the issue, remove coil, use emory cloth to clean the mounting area for the coil. Trash or oxidation can prevent a good ground on the coil. Lastly make sure the air gap (distance from flywheel to coil is correct) itshould be .012"
Oct 16, 2014 | Husqvarna Chain Saw Models 51, 55
358.794780 gas blower vac. Won't start, no spark. Replaced coil still no spark
This unit should have a magneto not a coil so better find out what you replaced and check with a dealer or repair centre for your model
Oct 12, 2014 | Garden
What is the A-coil that is compatible with furnace model KG7SC072D24B?
Looking at the model # it appears that you may have a 2 ton unit. Evaporator coils come in different sizes -
You should be able to get the correct size by providing the A/C repair company with the name of the manufacturer and the Model Number.
Generic coils, should you need one because yours is no longer being manufactured, do come in all different sizes.
I don't know if you want to replace the evaporator coil or have a service company do it. But if you do there are some things you need to know.
If the unit is an older unit the evaporator coil along with the box it sets in needs to be replaced because the drain pan is probably rusted out.
Additionally the box the new coil sits in is is going to be different in size then the original.
So a transition will need to be made from the furnace to the new A-coil box.
So with all that being said - if you have a credible A/C company replacing the coil you won't have any problems with them finding a replacement coil. They are in the business of doing this type of work and come across this situation all the time.
Oct 06, 2014 | Heating & Cooling
Number 1 cellender is running to ritch and miss fire ,how do I fix it , how to fix it
Pull the plug in cylinder #1 and inspect it for corrosion, burnt or rich with gas. If corrosion or burnt replace plugs if wet with gas and the plug is in good condition replace distributor cap and rotor, if this model has coil packs replace the coil pack that covers cylinder #1 it may also cover another cylinder as we'll some of the earlier models had two cylinders per coil. Hope this helps
Oct 20, 2013 | 2000 Chevrolet Cavalier
Lawn mower not sparking any ideas
pull the wire going to kill switch - recheck for spark if spark grounding switch, if no spark
pull wire off the coil retest if no spark faulty coil indicted
but be sure that unit is not a point model coil 1st
if a point model coil you will see a approximatly 10 mm gap on either side of coil winding and armature legs where it mounts
if briggs coil that is , if so most likely point and condensor need replacing
but if a magnetron coil unit then magnetron is faulty
replace it & set air gap to 0.010 " and reconnect kill wires
cheers paul
Aug 10, 2010 | Garden
How to replace spark plugs on 2000 jeep cherokee classic 6 cyl.? Also does 2000 cherokee have inline fuel filter?
TO REPLACE SPARK PLUGS YOU REMOVE COIL PACK MOUNTING BOLTS THEN REMOVE THE COIL PACK WITH BOOT OVER THE SPARK PLUG.YOU HAVE 6 INDIVIDUAL COIL PACK TO EACH CYLINDER. YOU NEED A 3/8 RATCHET WRENCH - LONG 3/8 EXTENSION -SPARK PLUG SOCKET - SPARK PLUG GAUGE.AND TORQUE WRENCH.THE 2000 MODEL JEEPS FUEL FILTER INSIDE THE TANK.1993 - 1996 MODEL JEEPS FUEL FILTER LOCATED LEFT SIDE OF THE VECHICLE NEAR THE FUEL TANK.
Jul 20, 2010 | 2000 Jeep Grand Cherokee
Looking for evaporator Coil number for Carrier Model 24ANA736
Are you replacing or adding an evaporator coil to this system? If replacing, please give us the model # (and product #) of the evaporator coil. If you can't find one for it, we will need the air handler (or gas furnace) model # so we can help you match it up.
If you just want the condenser coil for that condenser, the part # is 331230-7035.
Mar 24, 2010 | Carrier Heating & Cooling
Roper dryer ignites then shuts off
You need to replace the coils (comes 2 in the kit ) on the burner valve .Remove the front panel and the 2 coils on the valve are hold on by a bracket with 2 screws . Unplug the coils (no need to turn off the gas ) and replace , makeing sure the little dot is in the hole atop the bracket . When the coils get hot from electricity going thru them , one will "short" internally , until dryer cools down . Then will work for a short time and stop heating again . When you go to get the coils , take the model number off the plate (open the door and there will be a model/serial number ) and take it with you . If you had listed the model number here , I would have given you the part number .
Aug 16, 2009 | Whirlpool Dryers
Kenmore 73952 Gas Dryer Logo
168 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
