Question about Kyocera Mita FS-3800 Printer
What is a binary data - Kyocera Mita FS-3800 Printer
    President:
  • 1,185 Answers
It is the numbers used in a low level programming language which is used to program a number of different machines.
It is a series of Ones and Zeros which when grouped together form commands.
A number could look like 00110010
There are millions of them in big programs
Posted on Oct 03, 2009
How to write a program to translate english text to binary string and write a program to do inverse 27 = . , 28 = , 29= ? 30 = . 31=
to convert from text to binary, you would do something along the following lines..
1. have the user enter a string.
2. loop through the string (for each char in stringEntered..)
3. convert the character to binary using the methods provided to you by your language of choice
For the reverse (binary to text):
you must take 8 bits of data (which would be a single character), and convert it to text using the methods provided by your language of choice..
here's some links that might be of interest to you.
Visual FoxPro VFP CTOBIN and BINTOC Functions Equivalent In Net The Most Accurate and Reliable Source Code Converters
Feb 06, 2015 | Microsoft Visual Studio 6 6.0 Professional...
Ricoh 2232 binary bata error on duplex printing
verify you are using the correct driver, there is more than one for that. Other than that check the default settings in the driver.
Jan 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
Jan 27, 2014 | Yamaha HTR-5840 Receiver
Fault code 131 and 132 on bmw e46
EGR valve (Incorrect signal)
131 CAN time out (instr
2)
Input binary
stream bit data (0-
12V)
CAN message between DME/EGS
not received within expected time.
132 CAN time out (instr
3)
Input binary
stream bit data (0-
12V)
Nov 26, 2010 | BMW 323 Cars & Trucks
What is the binary representation of the decimal value 22?
binary is a real cool way to record numerical values
for future reference, a binary sequence represents multiple values being added to produce the total.nthe value of each unit is dependent on its location in reference to the farthest figure to the right.
EX:"011010" means "0+16+8+0+2+0"
so 22 would be "10110" in binary code (16+0+4+2+0)
Please rate this post as fixya!!!!
Mar 23, 2010 | RAD Data Communications RAD WEB RANger-II...
Problems with Mac 10.5.7 Installation
what program are you trying to print from on the Mac? I ran into a similar problem with Quark. here's that solution:
went through some Quark forums on line and read everything about printing problems with Quark 7 or 7.3. Most posts blamed the printer or the driver. However, the common theme was that it was only Quark and not earlier versions.the CUPS filter solution is no helpIn QuarkXPress, you can choose a data format to specify how the data for the pictures in your layout are sent to a PostScript printer: Binary, ASCII, or Clean 8-bit. Because binary data may be incorrectly interpreted through certain network printing protocols, or because your specific PostScript printer may not be able to interpret Binary data, you may need to change the data encoding method from Binary to either ASCII or Clean 8-bit. Please see the More Information section of this article for a detailed discussion of how these encoding methods differ.
Solution: Go to File > Print and select the Pictures pane. In the Data field of the Pictures pane, select either ASCII or Clean 8-bit.
Jun 02, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Hard disk formet
Formating harddrive doesnt mean you already lost your data. It is being converted into binary file so there is possible to recover. The problem is you need to buy a data recovery to recover all the data lost in your harddrive.
I can help you but you need to buy the recovery for $99.00. Gurranted money back if the problem did not meet your requirements.
Rate me SOLVED!
Philip
Nov 19, 2007 | Computers & Internet
Kyocera Mita FS-3800 Printer Logo
59 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
