Question about Echo Garden
Gas hedge trimmer echo 151 is leaking from rubber gasket on gas tank
5 Suggested Answers
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
cactus bob
  • 267 Answers
SOURCE: Looking for owners Manual for Echo HC 1500 Hedge
this is the same attachment as mantas tillers use to make there tiller motor into a hedge trimmer try there website for a download ................if this answer helped please rate 3 or 4 stars this will keep me in the paid answer department
Posted on Apr 02, 2009
lemmingleejn
  • 173 Answers
SOURCE: Echo SHC-212 hedge trimmer starts and runs briefly
If it has not had a service recently, it's probably due by now.
Just take out the spark plug, and if it's black, or 'coked' up, just show it a wire brush.
Also, remove the air filter, and if you have one, show that, a compressor. (or alternatively, just bang it about a bit, till all the loose debris, and collective build-up, are removed.
Afterwards, (if that doesn't solve the problem),
you can adjust the timing, quite simply, by closing, or opening, the gap on the plug.
Or you can open or close the space between the contact, and the magneto.
Both can be very 'effective' means of adjusting the timing.
If problems still persist,
you know who to ask.
P.s. and don't forget to give the thumbs up ;)
Posted on Jul 31, 2009
dmiesner
SOURCE: ECHO HC-1500 hedge trimmer wont stay running cuts off
Replace the fuel cap.
Posted on May 29, 2010
Gas mixture for Echo 1500 hedge trimmer
Kathy, Gas mixture 50:1, with mid or premium gas.
Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.echo-usa.com/getattachment/f9348047-25e4-468f-b298-f5927ec23249 2 Cycle Oil Mix Chart
Small Engine Repair How to Calculate or Mix 2 Stroke Oil with Gasoline or...
Jun 23, 2016 | Echo Hedge Trimmer Throttle Cable...
Echo srm-210 powers up fine on a flat surface, but it cuts out after a few seconds in the upright (usable) position. I rebuilt the carb, cleaned muffler screen, good gas and fuel filter. tank lines seem...
Make sure you rebuilt the carb with a carb kit. Put a hose on each pipe coming out of the carb and blow and suck on them. One should seal completely and one should provide vacuum. If there is a leak, you need new check valves. If you rotate the trimmer and it runs poorly, you may have a pierced diaphragm.
Oct 22, 2013 | Echo Zama Carb Kit For Shc210 For Rbk66b...
Poulan hedge trimmer GHT 225 it is a dash 2 How to adjust needle valves after replacing fuel lines (they are on the correct sides) the switch wires aren't pinched or broken and fuel seems to flow when...
The small green rubber thing sounds like the duckbill vent for a gas cap. Since the gas cap vent sits right over the open hole of the tank, I would check the underside of the gas cap. See if the little rubber vent is there. Normally, they will use a small clear nylon connector to hold the return line inside the tank. The small green thing sure sounds like a fuel cap vent. Here is a link to the diaphragm carburetors site with a tutorial on tuning these little carburetors. I will give you one from Zama and one from Walbro....Zama first.
http://www.zamacarb.com/tipspage.html
http://tech.flygsw.org/walbro_tuneup.htm
Jun 08, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
The trimmer starts but will not keep running, I replaced fuel lines and filters and put a rebuild kit in the carb. Same problem, starts fine but will not keep running
Its a longshot but I had a problem with my hedge trimmer, it kept cutting out when idling.
It turned out that a clutch spring was broken so the clutch shoes had nothing to restrain them and would fly out and make contact with the clutch drum and stall the machine.
Air locks in the fuel lines will also cause this symptom. These can be caused by running the machine with low fuel level in the tank and cutting upside down or at a sharp angle.
Mar 01, 2011 | Echo Gas 20 In Bar Double Reciprocating...
My Echo SHC-212 will start and slow idle but when I give it gas it boggs and stalls. I've changed the spark plug and I'm using the proper mix. Any suggestions? I was thinking of trying to clean the carb...
The prior posters must be from the Briggs & Stratton era :0] This is an EPA carb. You can only adjust the idle speed. The Echo SHC-212 uses the Zama RB-K75 carb.
My SHC-212 had the same bogg/stall symptoms. I had to disassemble and clean the carb to get rid of it. There is an internal filter screen that sometimes clogs. I soak and use compressed air to blow out all orifices. But the real problem is leaving ethanol gas in the carb during storage. It warps the delicate gaskets/valves. So buy Zama rebuild kit.
Dec 24, 2010 | Echo Zama Carb Kit For Shc212 Hedge...
Runs in idole, but boggs down and quit when i give it gas....(double edge echo hedgetrimmer 1500 gas power
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Dec 03, 2009 | Echo Garden
Echo manuals hard starting hedge trimmer 1500
all echo manuals are available on line at echo.com for free
Nov 01, 2009 | Echo 21.2 CC Shafted Hedge Trimmer
Garden Logo
151 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
