Question about Hitachi Travelstar 5K100 HTS541080G9SA00 80GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26924FT) Hard Drive
Replacing laptop HD
My laptop used
Travelstar 5K100 HTS541010G9SA00
I need to replace, what would work and maybe be faster
thank you
    President:
  • 2,600 Answers
Spend the money and go with a 7200 rpm drive, 160, 320, or 250 gb hard drives are all under 100 bucks these days.
Posted on Oct 03, 2009
Testimonial: "thanks"
I have a HITACHI TRAVELSTAR HTS541060G9SA00. iIt does not work. They say me that if I find another like it, they can recover the data. How can I get a disk drive, o what can I do? Thanks
If they can recover data, they will can repair too taht hdd, if they not know how, say them with Live CD Hiren's boot, in there 2 program realy working for rapairing, MHDD, and in Hdd tools\ TEST AND REPAIR HDD
Jun 03, 2011 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Which of Hitachi Hard discs could be a better replacement for model HTS541080G9SA00???
Just choose Hitachi Travelstar 320 GB, 5400 RPM, SATA , 2.5'' for convenience files storage.
Dec 19, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
How to download the driver of Hitachi Travelstar 5K100 HTS541060G9SA00 ? plz plz help me
I am not familiar with Linux but have you checked your Bios to see if Sata Hard Drive is recognized in there??? Most of the time you have to set the bios to recognize a Sata drive because 90% of Hard Drives are still IDE and most bios software is still recognizing the IDE drives. I know I had to reset everything on my Motherboard and Bios when I changed over from an IDE to SATA Hard Drive.
Nov 01, 2010 | Hitachi Travelstar 5K100 HTS541060G9SA00...
I am replacing a Hitachi Travelstar 5K100 HTS541080G9SA00 80GB with a Western Digital 500GB SATA 3Gb/s Hard Drive 8MB 5400RPM 2.5IN Scorpio Blue. A tech told me to use a cloning software to switch the...
You would need to use a "usb" to hard drive cable. It looks like this: http://gizmodo.com/168149/brando-sataeide-to-usb-20-cable
Then, it is simply a matter of "cloning." The other alternative is to find a pc repair shop with a hard drive duplicator. It will copy much faster.
Please rate if you find this helpful.
Sep 20, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Poweron laptop hdd not found
there is a problem on hardware get it to be checked
Nov 24, 2009 | Hitachi Travelstar 5K100 HTS541060G9SA00...
Hitachi Travelstar HTS541010G9SA00
No the drive is not customized at all. It is a standard SATA Data and Power connector. However, if it was already mounted in a laptop chances are the laptop manufacturer may have put an adapter on the connector end to allow for tight right angle insertion into the laptop chassis which isn't possible with the stock connectors without leaving the drive loose in it's slot.
If this is the case grabbing the connector and pulling straight away from the drive should pop it loose and reveal the stock SATA connectors under it.
If you're having troubles removing this peice, comment back with the make and model# of the laptop it came out of and I'll see if I can pull a diagram for you.
Chris
Jun 04, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
Unusable drive with bad sectors in drives service area
I would temporarily attach it directly to your laptop and go into recovery console and do a chkdsk /r on that drive
see if that helps, if not then there are things you can do.
post back for more info
May 17, 2009 | Hitachi Travelstar 5K100 HTS541080G9SA00...
#1508 Bad directory buffer signature
Hi, if this is a fairly new installed XP you're probably better off: repartitioning, reformat and reinstall WinXP but this will delete all contents of the hard drive. If however there are a good number of critical/important files you would want to save/copy, there are two (2) ways of going about saving/copying those files but both involve access to a working computer. (1) remove your Travelstar 5K100 from the laptop and using a 44 to 40 pin adaptor, connect it to the working pc which should recognize it as another hd and therefore you can copy your files to that pc. There are many sites that explains how to do this. You can try Google search or http://search.techrepublic.com.com/search/laptop+hard+drive.html. (2) another method is to boot and run your OS from your cd. While this does not involve physically removing your laptop's hard disk, it might be a bit challenging preparing the bootable CD with an OS. The procedure is better explained at http://www.nu2.nu/pebuilder/. This will run your laptop although a bit slow however, you can access the hd and save it to a thumbdrive or if you have a lan to another computer. Please let me know if this works ok with you. Good luck and regards.
Mar 29, 2007 | Hitachi Travelstar 5K100 40 GB Hard Drive
Computers & Internet Logo
361 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
