Question about General Electric 29568GE1 Corded Phone
Speed dial We don't have a book, how do you program the speed dial?
    Problem Solver:
  • 10 Answers
There is no Speed dial on that kind of phone.
Posted on Oct 04, 2009
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
Speeddial numbers
Select menu >phone book -contacts> take options and scroll down to speed dial >select number from the phone book to be assigned from the speed dial as it will assign automatically from 2 to 9 or as you want to select and asssign
Jun 29, 2012 | NEC Ip2at-12txd Phone/telephone Handset...
Need an electronic copy of the phone speed dial list - so I can print a new one
If you have access to programming, you can export (TOOLS Export tab) them to a spreadsheet and print it from there. Keep in mind I'm only the messenger, so if you don't understand or know any of what I've just said, ignore this answer and don't post it as "somewhat" helpful.
That's the book answer of how you export the speed dial list. There is no other "magic" command to do it.
Carl
Jul 16, 2011 | Panasonic KX-T7630 Corded Phone
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
How do i change a speed dial number on my brother mfc-7340?
Changes to the contents stored in the address book do not become effective in the stored speed dial numbers in Windows®. Description:If you have made a change to the contents stored in the address book, the speed-dial is NOT automatically updated.
If you change the address book entry, please follow the steps below to store the speed dial number again.
  1. Click on the setup button to open the Brother PC-FAX Setup dialog box.
    Notes:
    You can also access the Brother PC-FAX Setup dialog box by clicking start => Programs => Brother => MFC-XXXX or MFC-XXXX LAN (where XXXX is your model name) => PC-FAX Sending => PC-FAX Setup.
  2. Click the Speed Dial tab.
  3. Select the Speed Dial No. which includes the member or group you made a change in the address book, and then click Clear.
  4. Click the Speed Dial No. you want to program.
  5. Click the member or group you want to store on the Speed Dial again and click Add.
  6. The Speed Dial is now registered with the new entry. Click OK.
If you put the patch below, the message that prompts you to confirm the destination number or address will appear when you send a fax using the speed dial. Also the message that indicates changes in the address book do not become effective in the stored speed dial numbers will appear when storing a speed dial.
  1. Make a temporary folder on your HDD [hard disk drive] as the location to save the downloaded self-extracting file, e.g. C:\brodnt
  2. Please click here to download the patch. (7.07MB)
  3. The Brother End-User License Agreement will appear. If you agree to the terms, click I ACCEPT.
  4. Download the file to the temporary folder created in Step 1.
  5. Once downloading is complete, open the folder and double click PCFAXUPD.EXE.
  6. The installation will start. Please follow the on-screen installation directions.
Trust this is helpful. Please vote. :)
Dec 11, 2010 | Brother MFC 7420 All-In-One Laser Printer
Samsung s8300 how do i speed dial using keyboard
Hi, I found a way to get Speed Dial on the Eternity or Ultra Touch . As follows: [most of this from Phonebook/More/Settings/1 ]
1. Copy all address book entries from Sim to Phone Memory.
2. Delete all Sim Address book entries.
3. Switch Address book source to Sim.
3. Re-enter up to 99 speed dial entries in Sim, in the exact order you want them to be assigned to speed dial.
4. Switch Address book source back to Phone Memory.
From now on all numbers on the Sim will be in Speed Dial and you will view the address book from phone memory. Of course any number can be in both places.
Now to speed dial just enter 1#, 2# etc for any number in the Sim Address book. You will get to view and confirm the entry and then dial. In a way this is even better then the speed dial functions on older Samsungs, as the preview before dialing ensures you have the right speed dial entry.
I think it works fine. dk
Jan 30, 2010 | Samsung S8300 Ultra Touch platinium-red...
How to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Sep 11, 2009 | HP Office Equipment & Supplies
Speed dial
Jun 20, 2009 | Samsung S8300 Ultra Touch platinium-red...
Vu 204..new phone, speed dial does not work, goes to verizon wireless message which says call cannot be completed as dialed. Checked numbers they are OK, also happens which #1 for speed dial of *86 which...
I had the same problem and found that the speed dial feature in "settings" is not turned on by default even though voice mail number is pre-programed into the speed speed list. Go to "Settings & Tools/Call Settings/One Touch Dial" and turn the option on.
Cheers,
Don Devine
Mar 30, 2009 | Motorola Mobility VU204 Cell Phone
Re-programing speed dial fax numbers?
Go to the Menu, select Phonebook Entry. I think it is option 3. Then select the option you want to change (Speed Dial, Phone Book, or Group). Select Modify. From there you can make changes to the phone number or name.
-M
Aug 20, 2007 | Xerox WorkCentre Pro 765 Laser Printer
General Electric 29568GE1 Corded Phone Logo
50 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
