Question about Toshiba Qosmio G15 Notebook
Lines on Toshiba Laptop
Lines on screen
  • 3 Answers
I have the F15-AV201 (purchased in 2005) and it had the vertical lines on the display (appeared six months ago). This is a defect, on the nVidia graphics chip.
Since the chip is soldered on to the system or mother board, the only fix is to replace the entire system board.
I called Toshiba around April 10, 2009. The person I talked to was in the Philippines. Oh, the number was 800.457.7777, then at the first prompt press #1, #3 then #1 (rather than waiting for each prompt.)
Told them the model number and that I heard Toshiba was replacing the system board at no charge. I called it the "Northstar System Board Replacement Program." He looked up my serial number info and said that it qualified for the "SYSTEM BOARD ENHANCEMENT PROGRAM."
He sent me a UPS prepaid box, sent the notebook in, got it back about seven days later! It had an updated system board that included a better nVidia graphics chip. A system check indicates it has the GeForce Go 6600.
Note: I did not have to argue with the CSR, it's like they are told not to argue and simply arrange for the repair. Cool.
Note: I got the notebook with Windows XP and all original software installed. It's like they used the System Recovery disks to reinstall everything.
I did include a post-it note saying that the OS was messed up. Also, included with the return were two CDs that contained drivers and applications that are in comport with the new system board. The instructions said to install XP with my old recovery CD, but for all other drivers and apps, to use the two disks they sent me.
So cool that Toshiba is doing the right thing and fixing these at no cost to us.
Posted on Apr 23, 2009
    Problem Solver:
  • 11 Answers
Try to connect an extern screen from your notebook if the problem continue the there is a problem with the notebook but nt the screen
Posted on Dec 23, 2007
3 Suggested Answers
  • 84 Answers
SOURCE: Vertical lines in my laptop screen
There could be three different possibilities why you would get a line on your lcd display.
First, it could be a missing signal from the controller IC to LCD driver IC
Second it could be a defective LCD driver IC itself
Third it could be a dry contact in the tape carrier package ( TCP).
Attach an external monitor to your laptop and make it your primary display unit to see if you are still getting the lines if not its you TCP if you still get lines it will need to have either the LCD IC or the controller IC checked and possibly replaced.
Posted on Feb 11, 2008
  • 1087 Answers
SOURCE: toshiba satellite laptop has white lines on screen
Pull the lcd monitor out of the plastic frame and check for a loose wire connection where it leads back to the motherboard. If your lucky the backlight tube wite worked loose if not you will be looking for a new lcd screen. http://www.screentekinc.com/
Posted on Dec 30, 2009
How to fix lines and freezing screens on toshiba laptop
If there are lines through the display you probably have a bad screen. You could get it replaced, but it may cost several hundred dollars. It may be more economical to replace the laptop.
Jul 19, 2014 | Toshiba Satellite Computers & Internet
My Toshiba Tecra S1 Laptop has lines up and
hello,
the flex of your is either getting weak or it has shifted from its original location.. the flex is what connects the screen to the panel of the laptop and when it has a problem you experience lines on your screen..
what you should do is to open up your laptop and try to set the flex to its normal position and see if it stops the lines on your scree, if it doesn't then you have to change the flex
if you cant open your laptop,get someone with experience to help you
goodluckk
Feb 18, 2010 | Toshiba Tecra S1 Laptop Notebook
My satellite toshiba laptop shows a screen of fine colorful lines
did you ever try to go on gateway site to find a fix or microsoft.com to see if there is a update display driver for you computer
Feb 10, 2010 | Toshiba Computers & Internet
Lines in the lower part of screen
If it is still in warranty contact Toshiba.
Good Luck.
Mar 15, 2009 | Toshiba Satellite A205-S5879 Laptop
Vertical lines on screen
Everything can be fixed.
Try hooking up your laptop to an external monitor. If you get lines then the problem is the video card.
If not, it's the lcd, usually it is anyways.
Just replace the lcd and your problem is gone.
Best of luck!
Feb 25, 2009 | Toshiba Satellite P105-S6207 Laptop
Screen as lines coming down screen of my toshiba satellite laptop
Boot the computer in BIOS and if you sill have lines than the LCD is leaking.
To boot to BIOS tap "F2" OR "F10", multiple times as soon as you hit the power button to turn on the computer/
Regards
Sammy
Aug 28, 2008 | Toshiba Computers & Internet
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Black lines on my laptop
am sorry your screen is bad you hav to replace it
Jan 30, 2008 | Toshiba Satellite Pro 4600 Notebook
Toshiba Qosmio G15 Notebook Logo
621 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
