Question about Garden
My craftsman riding mower mowing deck release lever gets stuck 3/4's of the way down when I try to dissenagage the mowing deck. I need to reach over and manually pull a mechanism that sits next to one of the belt wheels to disengage it completely
  • 472 Answers
YOU MAY WANT TO LUBE THE PULLEYS UP WITH SOME WD 40
Posted on Oct 04, 2009
Mower shuts off when brake lever is released down to mow
sounds like a bad switch. unhook and check them (seat brake and deck)
May 29, 2016 | Garden
How do I determine why the blades will not engage on my mower
With the mower turned off and the deck at its lowest setting, check the top of the deck for any debris like rocks or sticks. Then watch the top of the deck while you move the engage lever. If nothing is moving, you either need to adjust the cable, reattach the cable, or install a new cable. If you see the lever with the pulley on it moving, when the engage lever is locked on, check the tightness of the belt. If it's loose, that is your problem and it could be a stretched belt.
Sep 18, 2014 | Craftsman Garden
Need to know how to operate the adjustment knob for the cutting heighth on the deck lift component on a Craftsman MV18S - 58560 riding mower
that model # is for the engine
the knob should screw in or out
pull deck lever up screw knob either in or out release deck lever
Apr 29, 2013 | Craftsman Garden
I need to how to install spring for the brake lever for blade pulley on deck. I have the end on the lever figure out. The other is the problem.
The brake lever has a hole in it as you must have found the other end attaches to a finger bracket that sticks up from the mow deck.
Oct 25, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Its not mowing evenly
You need to level the deck. On most mowers you level the deck from side to side evenly but have the front of the deck 1/4" lower than the back.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman riding mower LT3000 blades won't engage/turn
Well, we wouldn't want to lose your little girl, but goats can be very lovable.
The problem could be it just needs lubricating. I'd first spray WD-40 on every part of that mecanism which moves, top to bottom, even inside the button on top and underneath the deck.
If that doesn't work, get back to me, please.
May 09, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
