Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Eos 300d will not power up. charged new battery, no help. Checked CF pins, all ok, no change. Replaced back up battery, didn't help. Still will not power up?
  • timbup2 Oct 03, 2009
    no help i didn't already have
SOURCE: Canon EOS 300D Power On
Re attach the lens. Sometimes they don't sit right and cause this.
Posted on Dec 31, 2007
cammedic
  • 667 Answers
SOURCE: CF pin
I'm afraid they break most of the time. You can try it though since the repair involves replacing the board that the connector is soldered to, $$$
Posted on Jan 06, 2008
koraypek
  • 6 Answers
SOURCE: digital rebel EOS 300D
The card reader on this camera is soldered on the mainboard, therefore it requires professional SMD soldering equipment and skills, sadly, not a DIY job. You either sell it for parts on ebay, or buy a broken one (with a good mainboard) from ebay, and replace the mainboard. That should cost you around £50-60 (far less than a professional repair job)...
Follow this link on disassembling 300D (in case you want to replace the mainboard yourself)...
http://ghonis2.ho8.com/rebelmod.html
Good luck!..
K.
Posted on Sep 21, 2008
old marine
  • 1975 Answers
SOURCE: Accessing internal memory on the Canon Digital Rebel EOS 300D
There is no internal permanent memory. There is a buffer that holds data momentarily while the data is written to the memory card, but the buffer is flushed after each shot or series of shots. Sorry.
Posted on Jun 09, 2009
  • 66 Answers
SOURCE: Canon EOS 300D will not take photo's
do you get black frames or no record at all???
Seems like your sensor went dead on you....
Posted on Jul 09, 2009
I need to buy a CF PIN CONNECTOR. Do you know where i can buy the part?
Sony like to call this assembly the "MM-076 Board" if it is not soldered directly to the main PCB of the camera. I just checked the service manual and it looks like it is soldered to the PCB, so you will have to unsolder every pin and solder on a new one. Thankfully CF is all the same so this part should work for you:
http://www.darntoothysam.com/products/Canon-EOS-Rebel-300D-SLR-Compact-Flash-CF-Card-Reader.html
Hope this helps.
Thomas
Jul 24, 2011 | Sony Alpha DSLR-A100 Digital Camera
Hello, My Canon EOS 300D has no display and says busy in the view finder and in the lcd screen also. The focus and flash still work. Can you please tell me what could be the problem. I have taken out the...
Hi I think your unit has memory card receptance unit bad.( the CF card inserting area pins---bent and shorting), or some of loosen screw moving around and shorting. Mostly it is the pin problem. Your local repair shop would charge around $50 to 195 depend on what they really want to charge. If you are going to repair shop, ask them check your CF card female socket condition.) Thanks and best regard!
May 26, 2011 | Canon Digital Rebel / EOS-300D Digital...
Im getting an Error 99 on my EOS-300D Digital Camera when I turn off my YN 465 Speedlite flash gun (still mounted) and then I start shooting manually without the flash. Help please, its a bit annoying, but...
To fix this err99 issue, do the following
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera.
If it appears again, then proceed to next steps 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera.
If you still get the error you should send your product to canon for servicing.
Apr 15, 2010 | Canon Digital Rebel / EOS-300D Digital...
Jul 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
CF Card not found
Ok here is the issues with the Canon 300D digital Rebel XT model of camera. First issue bent pins or broken pins the CF card reader on this camera is Surface mounted soildered onto the bottom half of the mainboard a large ammount of disasimboly is required. After removing the mainboard next you need is a desolder rework station. to carefully remove the CF card reader from the mainboard one messup and it might be easier to replace the mainboard. Sometimes. next issue is the power issue if you have no bent pins or missing pins, and the battery door is pushing on the door closure switch and the memory card door is pusting on its door closure switch then most likely you issue is 1 of 3 fuses underneath the power switch. these switches are the size of a few grains of salt very very small.I charge 150.00 to change the fuses and 225.00 to replace the CF card reader as long as none of the traces are damaged. if they are damaged the main board would need to be replaced and it is around 250.00 + depending on the parts cost at the time. If your good at soldering go for it. if not then let the experts do it.
Dec 22, 2008 | Canon Digital Rebel / EOS-300D Digital...
My camera won't turn on. i've tried switching batteries, but that's not the problem. can you give me an idea of what's wrong?
Sep 02, 2008 | Canon Digital Rebel / EOS-300D Digital...
NO POWER
I would have to agree sounds like a motor or gear that the motor turns.
Dec 10, 2007 | Canon Digital Rebel / EOS-300D Digital...
Camera does not work when memory card is inserted
I have had this problem, and it was a bad CF card. Are you sure both of them are good? If a computer can read them, maybe try formatting them.
Dec 05, 2007 | Canon Digital Rebel / EOS-300D Digital...
Digital rebel EOS ds6041
This happens when image data cannot be written/extracted on CF card. Try a card that you know is ok ( works on other cameras ). If problem persists one or more pins in the CF card chamber may be bent or even broken off. Try to straighten but be careful not to damage undamaged pins... but may have to go to an expert for repairs.
Sep 13, 2007 | Canon Digital Rebel / EOS-300D Digital...
Canon Digital rebel Wont turn ON
This happened to me today. The lens drive sounded weird - like off gear. Then it froze and wouldn't turn off without taking out the batteries. Then, it would turn on. Now it's ok. What I did was remove the cf card, lens, regular battery, and the little battery that is also in the battery compartment. I let it all sit while I did other things. When I put it all back together it turned on and I had to set the date but everything worked fine.
Sep 02, 2007 | Casio Exilim EX-V7 Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
55 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
