Question about Brother CS-6000
Feed dogs dont move fabric thur
The feed dogs do not move the fabric thru. They do move up and down but not front to back therefore keeping the fabric in one place. It has been cleaned and I see no visible damage.
  • kasinda_dela Oct 04, 2009
    I have tried all the settings. I have even released the feed dogs for free motion and then reset them. I believe it is a lever or arm that is not moving the feed dogs in the circular pattern that they normal travel in. This could possibly be caused by a broken or stuck gear moving the arm. I have completely cleaned everything that I can get to and used canned air to blow anything else out.
  • Brother Master
  • 1,388 Answers
Have you changed the stitch length selector to zero ? If there is no lint trapped under the needle plate between the feed teeth, then the length selector is likely set too small,.
Posted on Oct 04, 2009
The fabric doesn't move when I begin sewing
Is your presser foot down? Do your feed dogs go down? If they do move the lever to the up position. The feed dogs are what feeds the fabric thru the machine.
Jul 04, 2017 | Sewing Machines
The pressure foot pressure is not feeding the fabric. I have adjusted the tension but still not feeding the fabric. What else can I do?
Tension does not affect the ability of the machine to feed fabric, except in extreme cases perhaps when tension is too tight.
You probably need to adjust the presser foot pressure of your machine. Lighter weight fabric is more difficult to feed, therefore the pressure needs to be increased. (Heavy weight fabric will sometimes push the upper layer of fabric in front of the presser foot, therefore less pressure is required.) Even so, very fine slick fabric (silk, satin, chiffon) sometimes still needs additional help. In such cases, a roller foot, teflon foot, or walking foot may be beneficial. There is also the possibility that the feed dog teeth have been worn so they do not grip the fabric like they should. (Avoid running the machine without fabric between the presser foot and feed dogs to protect the feed dogs from unnecessary wear.) If they are worn, usually they can be replaced.
Another possibility is that the feed dogs do not raise as high as they should. This would most likely require a technician's assistance.
Um, as an additional thought, make sure the presser foot surface is smooth. Any rough surface (nicks, rust, etc) will restrict the fabric's ability to move.
Jan 30, 2017 | Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
Why is the needle not moving or feeding fabric but motor is running
the needle only sews,, it's the feed dogs in the needle plate area that feed the fabric thru the machine, if the feed dogs are in the up position then the machine will sew, if the machine is not sewing then the feed dogs need to be checked to see if the feed dog lever is up or down, look in the manual to see where the lever is and check it, if the lever up the then feed dogs will need to be checked to see if there is something's wrong with them at a sewing machine repair shop.
Jul 31, 2014 | Janome Sewing Machines
Feed dog not moving
if the feed dogs are not working correctly, then the machine needs to be serviced
Mar 10, 2012 | Sewing Machines
I hav e Bernina 1150. When I attach the walking
Hi, when you quilt straight lines using the walking foot, you need the feed dogs up, to move the fabric in a straight direction under the needle. When you do free motion quilting, which is done with a darning foot, your hands move the fabric in many different directions. Since you want to be the one to move the fabric, you put the feed dogs down and you do the work. So when you use the walking foot, keep your feed dogs up. When you use the darning foot, feed dogs down.
Feb 20, 2010 | Sewing Machines
Fabric won't feed thru the machine
Does it have an embroidery setting? That keeps the feed dogs out of the way so you can move the fabric by hand.
Mar 13, 2017 | Husqvarna Sewing Machines
Fabric wil not feed thru machine
adjust your feed dog hight. manual shows u how
Dec 02, 2008 | Kenmore 15218 Mechanical Sewing Machine
Brother CS-6000 Logo
325 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
