Question about Sony Playstation 3 (PS3) Console
PS3 wireless connection not working
I am trying to connect my ps3 to the wireless internet connection and i am getting no where fast
  • 156 Answers
First, does the PS3 "see/find" the wi-fi?
If not, check location of PS3 in relation to transmitter and see if can re-locate either to find/improve.
When found, just enter wi fi "key" into prompt screen.....that should enable connection
Posted on Oct 03, 2009
3 Suggested Answers
maklean
  • 1665 Answers
SOURCE: PS3 WIRELESS CONNECTION
This code (80711008) is not reffered error code list
Try first to establish a success connection at a nearer distance. Your signal strength might not be strong enough to have a lasting connection
Posted on Jan 10, 2008
  • 4 Answers
SOURCE: PS3 wont connect to internet
Your PS3 should have WiFi built in unless you bought he 20GB version back when it first came out, that is the only one that dosn't have WiFi. But you can still connect it the way you want. You can use any type of ethernet cable, straight through or crossover. You need to go into your network connections in the control panel, select wired and wireless connection at the same time and bridge them. That should do it if you wanna go that route but you would have to have the computer on anytime you wanted to connect your ps3 to the internet. The best bet I think would be to just use the WiFi built into the PS3
Posted on Feb 14, 2009
Problem trying to get internet wireless
First, you have to have a wireless router connected to your modem. If it still doesn't work, you need to mess with the Network Settings on the PS3. Click on Internet Connection and check Enabled. Then you can go through the Internet Connection Settings and go through Easy or Custom and go through that. Then go to Internet Connection Test where it will test the internet on your PS3 if it's working right. Hope that helps!
Jun 16, 2010 | Sony Playstation 3 (PS3) Console
Cant connect to psn. But i can to internet. :(
One reason this may be happening is having the media sharing option on. Some routers can't handle all the requests the ps3 sends while having this option on. You're using a wireless connection right?
Mar 31, 2010 | Sony Playstation 3 (PS3) Console
PS3 and Netgear WGR614 V7 Router
Basically the PS3 wireless settings needs to be configures with the Netgear wireless router settings.
To test if the modem is connects to the Internet, connect a computer into the modem, if it works then the modem is configured correctly. If it doesn't work, then contact your ISP and get them to test your modem connection.
For details on how to configure the PS3 click on the WEB link :-
wii.php">http://fixhomenetwork.com/xbox-play-station-wii.php
Dec 20, 2009 | NetGear WGR614 Wireless Router
Wired nor wireless connections for my ps3 wont work
if you setup your wireless in adhoc mode like useing the pc wirless it wont work because ps3 doesnt see adhoc wireless.
and for the ethernet connection is the pc setup right. you have to enable internet sharing on the accuall interface that has internet..
If local area connection 1 is connected to internet and local area connection 2 is plugged into ps3 then under local area connection 1 settings you have to set share this connection and in the drop down menu select local area connection 2. other than that you need to buy a router.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Can't connect the wireless internet to PS3!! HELP
If you don't want your PS3 connecting to your wireless network, try going to the router control panel, and use the MAC filter to block it from connecting.
Apr 20, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Feb 14, 2009 | Sony Playstation 3 (PS3) Console
Playstation Network timed out
try moving ur ps3 closer 2 ur router dat should make da connection stronger. but another thing is wen da internet router is used by too many appliances certain ones for example ur ps3's internet becomes weaker. i hope dis helped=)
Jan 20, 2009 | Sony Playstation 3 (PS3) Console
PS3 -Connect to Internet using PC with wireless Broadband Card???
Yes you can but you need a router or ou need to connect the ps3 directly to your lan card the just set up a shared internet connection through windows
Mar 22, 2008 | Sony Playstation 3 (PS3) Console
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hook up to the internet
I have a problem. I have everything hooked up and when i go for a connection test it says my connection has failed because there is an DNS error. What is a DNS? and what do i have to do to fix it?
Sep 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
548 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
