Question about Meopta HA 70 Spotting Scope
I have a meopta hermes 1 (ha70). The problem I have is the collar that mounts to the tripod is broken. Any ideas where I can find a replacement?
How do I return wrong collar I received today?
contact the seller and tell them the wrong size collar was received .
May 20, 2015 | Pet Supply Imports Herm Sprenger Snap...
GIOTTOS tripod centre column require clamp to hold the column secure
That will depend upon which model and what is damaged/worn/broken. Without more info there is no help. you can send the tripod to:
SpartanPhotoCenter
197 East Saint John St
Spartanburg,SC 29306
We can give you an estimate to repair after we find out what model/ what part you may need. Generally repairs are $ 25 + Parts + return shipping.
Nov 23, 2012 | Giottos Photography
Where can I find replacement rubber feet for the Rocketfish RF-TRP65C tripod?
Go the the BestBuy store and steal one from a display. Apparently the feet are transported to earth from a distant galaxy; impossible to find. I'm certain they're made in China by the gazillions but can't locate a supplier.
Aug 02, 2012 | Rocketfish Mounting Plate For Rf-trp65c...
Broken tripod for edu science telescope
You can buy a photo tripod and attach the tube to the tripod. You may need to visit a local hardware store to find the correct mounting bolts.
That scope is sold by Toys R Us -- as far as I know they DO NOT sell replacement parts.
Sorry
Sep 26, 2011 | Edu-Science (10166) Telescope
Hi, I have a meade lxd55 tripod (with 8" discovery newtonian mounted on it). 2 of the 3 leg braces at the bottom that also hold the eye piece tray have broken. I need to replace 2 or all 3. Can I get...
Sometimes you can find these for sale at these web sites--
Sometimes--
http://shop.telescope-warehouse.com/
and here:
http://astronomy-mall.com/astro.parts.outlet/
You might try calling Meade directly:
http://www.meade.com/support/index.html
Mar 14, 2011 | Meade Optics
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
The diamond insert in the hub of the blade keeps falling out as soon as I start a cut. What is wrong?
DO NOT USE SAW!!!
1. switch off saw, remove cord from socket (positive electrical insulation)
2. lift table for maximum cut and check size of the washer holding the blade,
3. you should have holding nut with collar, collar is about 1 1/4 (32mm) diameter, then blade (diamond is actually universal reducing bush in some blades) and lastly you should have internal washer, again, about 1 1/4" (32mm) diameter. if your collar are smaller, you need to replace blade as not suitable for your particular model, albeit I am rather suspicious that you have wrong collared nut and internal collar. Please check if both collars are exactly this same diameter. Please check if collars cover diamond cut-out.
4. if you see discreptancy between description in 3, purchase suitable blade (external diameter is 7 1/4" (184mm), as you did not supply what model of your saw, therefore most probably shank is 5/8" (16mm),
5. mount internal bush (collar), will go correctly only in one way.
6. mount blade (pay attention to cut direction, cutting surface should be clockwise if you look at mounting shaft.
7. mount external flared nut
8. check blade for slippage and wobbliness
9. connect power cord and switch on/off
10. check saw blade againg for slippage/wobbliness
11. make test cut if 10 was correct
12. use normally
Do not forget that this is not a toy, it will cut through wood, ocassional nail and your fingers.
Opearating saw crate flying debris, always wear googles or facemask, you have only two eyes and there is no spares.
Please leave note how you go with this advice.
Aug 18, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Leg slips will not lock
Although I'm not familiar with your particular make and model it sounds like a common problem which affects many other tripods. If the legs clamp with a lever action then if you closely examine each clamp as you activate the lever I expect that you'll find a small crack opens up in the clamp assembly.
It's a faulty design as the clamps simply aren't strong enough for the load and eventually crack due to fatigue. Some manufacturers supply replacement leg clamps but they also fail and fitting them usually costs more than the tripod is worth.
Next time, consider buying a tripod which has rotating collars to lock the legs with. They're not as quick to operate as lever action (a.k.a. "quick release") clamps, but they don't take much longer and last far longer. Rotating collar clamps are only suitable for tubular legs, and to be as rigid as extruded profile legs there's usually an increased weight penalty unless you spend far more on carbon fibre versions.
Personally, I tend to buy cheap but perfectly good non brand name lightweight tripods which I can get for £10 including a carry bag and handle and expect to have to replace them when broken: usually about once a year. It's a lot cheaper than spending over £300 on a good one and means I can afford to have a spare one in the car.
ALDI (in the UK and Europe) sell a £10 tripod which comes with a handle, carry bag, pan/tilt head,quick release leg clamps, geared centre column plus two quick release mounting plates and has a bag hook at the bottom of the centre column; it even has a no quibble three year guarantee. It's not a smooth or as well built as many, but can't be beaten at the price.
Aug 06, 2009 | Vinten 3770-3 Tripod
Broken part on MT 8180 looking for replacement part
ACE Hardware.  What you are looking fore is a "wing bolt" as opposed to a wing nut.  They have them in both SAE and Metric.  At least our local store does.
Oct 29, 2008 | Giottos MT 8180 Tripod
Optics Logo
561 people viewed this question
Top Meopta Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Meopta Optic Expert? Answer questions, earn points and help others
