Question about Craftsman Garden
I'm having a drain on my Battery. Battery was about 4 years old, so when it did not want to crank i replaced it. Put a new one in last night and it fired right up, but this morning I had to jump it. Of course all this would happen right after I washed it. Could water have gotten in the ignition switch?
  • 389 Answers
If it is a Briggs & Stratton engine, they have a one way diode in line that has probably gone bad.
Find the wire harness that comes out from under your flywheel and plugs into the main wire harness of the tractor.
In that harness near the plug you should see an enlarged portion of the wire, that is your diode.
If you have a multimeter, check the continuity through the diode in both directions by first tapping into the wire with red on one side of the diode and black on the other, then reverse the leads. If you have continuity in both directions, replace the diode.
Posted on Oct 04, 2009
My car has been running just fine but all of a sudden last night i went to run to the store and it wouldn't start. no cranking, no lights, nothing happened. my husband came to try and jump the car off and...
start the car and pull off on side of the battery and if the car shuts off your alternator is bad if the battery wont stay charged its the battery .If you have a meter check the voltage to the battery it should be around 14.3 volts .
Oct 17, 2013 | Pontiac Grand Prix Cars & Trucks
Own a 1997 toyota 4-runner SR5. I live in Edmonton Alberta CANADA, where the winters are extremely cold. This truck has never had any major issues with the battery until this year....This is the 3rd...
if all you heard is a click when turning your key and after a few try's it will crank then the starter contacts are worn out, you can replace them easy or just get a new not rebuild starter. one more thing put a volt meter on your battery and crank your engine if voltage drops below 10.5 v battery may be at fault or starter is drawing to much current.
Mar 21, 2017 | 1997 Toyota 4Runner
My alternator is good & my battery still gets drained
How old is the battery? I learned at Sears while working there in the battery department that the average life of car batteries is about 3 years. So, after that, batteries lose a significant amount of their performance CCA or cold cranking amps, and may have to be replaced on a pro rated basis after that period of time, on average.
I put a diehard platinum battery into my 1997 Cadillac Deville Limousine for about $189.99 plus tax and it has a 4 year replacement warranty due to bettery construction.
However, if you get Walmart's best Maxx battery, they have a 3 year replacement policy and they charge about $79.99. I put that into my 1990 Cadillac Deville.
Good luck on resolving the battery drain problem with a good alternator.
Dec 18, 2010 | 1998 Cadillac DeVille
87 f250 drained brand new battery
I would first have the alternator checked by an auto electrician to ensure it is working correctly and is providing the correct volume of current. It may be faulty and when driving you will be drawing battery power instead of power from the alternator to run the electrics. This will drain the battery.
Alternators do not last forever and if you are still running the original unit it is likely to be on it's last legs and you will need a replacement unit.
Nov 30, 2009 | 1987 Ford F 250
2001 chev blazer, I (like a fool) left the lights on last night for a while and drained the battery. (truck usually starts and runs great) today went to start it and it turned and turned but would not fire...
Is the engine turning over as fast as usual, or is it cranking slowly? If the battery is 4 years old, it's near the end of it's service. 1st check connections to make sure they are clean and tight at the battery. Pull it out and bring it to a parts store for a check of it's condition. They should be able to tell you if its low charge, or if the battery is on its way to battery heaven. If it is shot, replace it, and let me know if it starts ok then. If not I'll try to help further. ...............................................
Nov 27, 2009 | Chevrolet Blazer Cars & Trucks
How do i check starter voltage on 1995 7.3 Ford F250? The batteries are less than a year old. They are being drained frequently. Today truck will not crank. Starter checked out by mech.
Sounds like you have something else draining battery. Possibilities include the alternator. For starter cranking voltage place the positive lead of voltmeter on positive of battery and the negative on the other. Disable fuel, then crank for 15 seconds and read volts while cranking. This is your cranking voltage. For voltage drop on cables, place positive on battery positive and negative at battery cable on starter. Crank 15 seconds. This should be less than .5 volts. The same can be done with any cable or wire in the starting or charging circuit of a vehicle. Just place the positive on positive or negative on negative, with the other lead at the opposite end of the cable being tested. In charging diagnostics, you will get the charging system operating with the engine running while you do the readings. I suggest though, that you do a parasitic drain check. If you disconnect the positive cable of the battery and place a test light in series (one end to battery, the other to the cable), you should have a very dim light to no light. If the light is bright, you have a drain. Proceed by making sure everything is off and there are no dome or hood lights on. Start removing fuses one at a time until the light goes out or gets very dim. Replace each one after you check it to avoid having a pile of fuses to put back. Also disconnect the alternator wiring to eliminate this possibility. A fried regulator may feed voltage to the fields all night if it's shorted. This will drain both batteries in relatively short time.
Sep 20, 2009 | 1995 Ford F250
My 2000 ford ranger and something draining battery
bad alternator possible or bad battery..even though its new that battery can be bad. I would take a volt meter and with the engine running check the volts of the battery..If the volts are 12 you need to replace alternator, if volts are 14 you need to check the battery. to check the battery hold the volt meter to the battery and have someone start the car..while the starter is cranking battery volts should not drop below 10volts.if they do your battery is bad.
Jun 11, 2009 | 2000 Ford Ranger SuperCab
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
Garden Logo
136 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
