Question about Kenwood VR-407 Receiver
Cooling fan comes a lot on 407 - Kenwood VR-407 Receiver
    President:
  • Kenwood Master
  • 1,114 Answers
If you have equipment stacked, that is normal, or if it's in a cabinet. If it's "stand alone" in an open area, get a can of compressed air and blow out the inside. PC boards are like dust magnets and it could be heating up due to a "dust blanket" Hope this helps
Posted on Oct 03, 2009
Where can I get a cooling fan wiring diagram?
The cooling fans should come with a sensor and tells fans to come on at certain temperature
Jan 02, 2016 | 1998 Plymouth Voyager
1998 saturn need know why engine cooling fan wont come on
they had a lot of coolant temp sensors go bad there plastic they crack and coolant gets into the harness unplug it and see if the connector for corrotion
Oct 06, 2012 | World Source One 1995 - 1997 Saturn SL2...
Man cooling fans are not coming on and i would like to know where the fuse is to the fans.
The fuse to the cooling fan relays are in the engine compartment. Depending on the model of engine you have it is either on the left or right side in a black box. You will see a lot of wires coming out of it. Pop that off and see what the fuses look like.
Could also be the thermostat. < an easy fix.
Aug 23, 2011 | 1993 Eagle Talon
Cooling fans will not come on my 1997 olds aorura
This could be a lot of things,check the fuse for the cooling fans,then check the coolant level,and if there is air in the cooling system this will happen,and of course the coolant sensor could be at fault,and the cooling fan relay.
Jun 05, 2010 | 1997 Oldsmobile Aurora
I have a new NB205 mini toshiba lap top and i am getting a cooling system error return for service. But if i shut it off and pull the battery sometimes it works for a while and the fan comes on.
I think the bearings in your fan are failing. When that happens there is a lot of resistance to turning to overcome because the bearings are dirty and dragging. You might be able to jolt it into running off and on but it won't run at full speed and it probably won't cool your system adequately. You just need to get the fan changed. It could damage your system running it without a fan. CPU's develope a lot of heat in a short amount of time.
Dec 18, 2009 | Computers & Internet
How do u change fan relays on a 92 seville 4.9l.
the fan relays are in with the other relays in the relay box,check the coolant sensor,or just replace it.If you turn on the ac,will the fans come on?If so,the relays are fine.be sure the coolant level is fine,and there is no air in the cooling system.This,along with the coolant sensor are the main causes for this problem.Is the cooling fan fuse good? I hope this will help you.
Oct 06, 2009 | 1988 Cadillac Sedan DeVille
My bmw 325i as heating problem,we replace the water pump,termostate,and radiator,but its still running hot ,any suggestion
my 1990 325i bmw is running hot
it seems to have a lot of air in the cooling system
i replaced the head gasket, water pump and thermostat
how do i get the air out of the system
Sep 16, 2009 | 2001 BMW 325
SONY VGNFJ270 LAPTOP BECOMES HOT AND GIVES LOT OF NOISE
If the fan is noisy and the laptop is running hot, then most likely the fan is faulty and spinning slowly. Therefore the fan is not providing sufficent air flow to cool the laptop's CPU. The fan needs to be replaced and possibly the heatsink assembly needs cleaned to remove dust buildup.
Jun 24, 2009 | Sony Computers & Internet
Water in tail pipe,fan don't come on by it self
some condensation is normal, but the cooling fan has three sensors. one on the water bottle telling the fluid lvl. one on the thermostat that tells the fan to come on and one on the block to shut it down when it is too hot. test the one on the thermostat.
Mar 10, 2009 | 1992 Plymouth Voyager
Kenwood VR-407 Receiver Logo
62 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
