Question about Boating
I have a 1978 mercury outboard 150 HP motor that run fine except when on full throttle it seems to loose power for a second then picks up again then looses power for a second then picks up again, what could cause this
  • Anonymous Mar 24, 2014
    The engine lacks power to get on plane and top speed
    Problem Solver:
  • 7 Answers
For the DIY boater it could be a number of possibilities - fouled plugs, old fuel, improper air fuel mixture or dirt in the carburetor.
Pull the plugs and check the color of the ceramic. Light tan is good. Dark and oily is an indication of misfiring, fouling and too rich oil or improper air mixture. Make a note of which plug came from which cylinder. If they're all about the same color (dark) replace them all. Properly set the electrode gap and install the plugs.
You could try spraying the intake with carb cleaner like "Gum Out"
to clean out the carbs too.
Drain and clean out the sediment bowl of the carb(s) test again.
If cleaning sdoesn't take care of the problem then you need to Reference a Mercury marine manual for initial air screw mixture settings, ie: air screw location and how many turns out are recommended.
Air fuel mix is adjusted by a screw on each carb. No more than a 1/4 to 1/2 turn should be made at a time. Test again.
Also when you store the motor for the season, get some "Gas Stabilizer" for the fuel tank. Mix the recommended amount in a full tank of fuel, run the motor for several minutes. This step will put the stabilized fuel into the carbs for storage.
Hope this helps.
Posted on Oct 05, 2009
2017 mercury 350 wont go past 5300 rpms? know a reason?
Check to make sure you are getting full throttle response, the linkage may have became loose.
Aug 29, 2017 | Mercury 2013 225 HP Verado 5.44" 1.85...
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
I have a 1978 merc 85 hp outboard with a bad pump i purchased a used one that works mine has 4 hoses
Mercury Outboard Fuel Pump - Mercury Outboard Forums
forums.iboats.com/Mercury-Outboards/Fuel-Pump
5, 2004 Mercury 225 four-stroke EFI no power to Low Pressure fuel pump. Why please help · Mercury & Mariner Outboards. 13, Mercury 850 (85hp) - Gas pumps through the top carb - Failed fuel pump? ... 1, 1969 7.5 H.P. Mercury (Bad fuel Pump)? ... 1971 · 1972 · 1973 · 1974 · 1975 · 1976 · 1977 · 1978 · 1979 · 1980 · 1981 ...
Fuel Pump Diaphragm replacement Mercury outboard 110 ...
? 4:18
https://www.youtube.com/watch?v=vufekxTVZd8
Jun 22, 2012 - Uploaded by Brad Clark
My last test run of this motor lead me to believe I had fuel pumpissues...so in ... Mercury 9.8 h.p. 110 Outboard Motor WaterPump Repair and ...
How to remove the lower unit on a Mercury outboard motor ...
Dec 01, 2015 | Boating
Outboard troubleshooting
hard to say but sounds like maybe you didn't add oil to the gas as required .
Jul 13, 2014 | Boating
Full throttle
check when its on full throttle that the carb butterfly is at 90deg and not over as this will reduce throttle but max advance on ignition !
Feb 11, 2014 | Seloc Mercury Outboard Engine Repair...
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
Aug 16, 2013 | Seloc Mercury Outboard Repair Manual, 1965...
Free wiring diagram for 1978 Mercury Outboard 115 HP boat motor
I have a maintainance manual for this engine (I have the same one) with pages of wiring diagrams. What specific system/area are you interested in, I could scan in the page(s) and email them to you.
Mark
Sep 19, 2009 | Boating
1996 Mercury 150 Nitro EFI outboard- just bought the boat, running fine on the lake for about 35 min. Motor is 2 stroke- oil injected, oil tank is full. While running at partial throttle, an alarm...
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Jun 13, 2009 | Boating
I have a 1987 mercury 9.9 outboard drive problems
the inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Aug 25, 2008 | Sport & Outdoor - Others
Boating Logo
332 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
