Question about 989 Studios Syphon Filter for PlayStation 1
I need code for syphon filter level expo center
  • 25 Answers
Press Start, choose Options, then highlight Select Mission and press Left + L1 + R1 + Select + Square + X
Posted on Nov 13, 2009
  • cullenz Nov 13, 2009
Why is my derwent macdee cistern not flushing properly and solids not going away?
Hi anon the toilet probably needs the syphon changing. The syphon causes the push down the pan for the solids to go.
Feb 16, 2015 | Home
Where is fuel filter located in 94 Mitsubishi Expo? Not the pump but the filter.
I think they are under the bonnet on these follow the fuel lines back from the engine
Apr 12, 2013 | 1994 Mitsubishi Expo
Where is the transmission dip stick in a 1992 nimbus
seems some automatic transmissions are sealed
____________________
Benz AK500
Sep 10, 2012 | 1992 Mitsubishi Expo
Instructions to replace fuel filter of a 1994 Mitsubishi Expo LRV
Relieve the fuel rail pressure by removing the fuel pump fuse, then cranking the engine for a few seconds until it is clearly not receiving any fuel. Next let off the pressure in the fuel tank by removing then replacing the fuel filler cap. Next unfasten the special connectors which join the fuel line to either side of the fuel filter and disconnect the lines, keeping a rag handy to catch the fuel which will spill out of the lines and filter. Remove the fuel filter mounting bracket bolts/screws then replace the filter. Reassembly is the reverse of removal.
Mar 21, 2011 | 1994 Mitsubishi Expo
What tools do I need to change my oil filter? I have a 1993 Mitsubishi Expo. The oil filter is in a tricky area.
as the oil filter is a canister type,just stick a screwdiver through it and unscrew it.
Sep 05, 2010 | 1993 Mitsubishi Expo 4 Door
I have gestetner 2722ztd copier when i replace the explosure lap the copier dispalys error code e1 on the screen .how i clean/remove the error massege ? please help me
Please check after replace the continuity the expo lamp,expo thermofuse.The E codes are displayed in the copy counter.To display both digits of the E codes press the enter key.
E 11 - Exposure lamp error.Possible cause: expo lamp open,expo thermofuse open,power supply defective,main board defective.
E 12 - Exposure lamp error.Posible cause:AC drive board defective,main board defective.
E 13 =Zero cross signal error.Possible cause:main board,power supply defective,zero cross line open or the conector on the main board is not conected correctly.
For reset turn ON/OFF the main switch unplugged wait 10sec and turn ON or:turn ON the main switch,turn DIP switch 101-1 ON/OFF and turn the main switch OFF/ON.The DIP switch is located in the rear parts into the main board.
Sep 20, 2009 | Gestetner Office Equipment & Supplies
What meaning the center panel light special the light like a circus toldo
The best way I can describe the warning is that it looks like a circus tent. This light represents the coolant level. If your coolant level sensor detects a lack of coolant, it will come on. I would advise filling your car to the proper level and also have a mechanic inspect your cooling system to find out why your coolant level dropped. Two other things to check are if you have any electrical current in your coolant, which can cause a false alarm, and secondly, that the sensor is not malfunctioning. Just a thought.
Hope this helps you all.
Sep 05, 2009 | 1992 Mitsubishi Expo
Base and exponet soucre code(recursor)
Hi Dear,
here is the code in c, for positive integeral exponent, you can convert it in any other programming language.
#include "math.h"
float (float base, unsign int expo)
int x=abs(expo), i;
if (x<=1)
return(base);
else
return(base*float(base, expo-1);
Hope this will help you out.
for any clarification please feel free to contact me
bye
Zulfikar Ali
ali_zulfikar@yahoo.com
09899780221
Mar 03, 2009 | Intel Computers & Internet
Fuel filter location on a 1994 Mitsubishi Expo LRV 2.4
it is an internal fuel pump located underneath the back seat..
Dec 04, 2008 | 1994 Mitsubishi Expo
989 Studios Syphon Filter for PlayStation 1 Logo
59 people viewed this question
Top 989 Studios Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Are you a 989 Studios Video Game Console and Game Expert? Answer questions, earn points and help others
