Question about Refrigerators
Hi, Our Frigidaire refrigerator section is freezing all the food. What should the temperature be? It just starting doing this and we didn't change the thermostat. Thanks, Robin
  • 4,070 Answers
Fridge should be around 35 degrees F. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Oct 03, 2009
Drawer Freezer. Doesn't completely freeze food
Good Morning Stacey, thank you for your post!
I understand that your Frigidaire refrigerator is not freezing food properly. What temperature is your refrigerator set to? How much do you have packed into the freezer? Is this a new refrigerator? Could you also provide me with your model number? You can locate the serial (which lists your model number) on the inside wall of your fresh food side. Once I have that additional information I would be able to assist you further. -Matt
Jan 03, 2016 | Frigidaire Refrigerators
My food in the fridge section is freezing in my Frigidaire fqe6307sae. How do I know if it is the thermostat and how do I adjust the temperature on the display?
I could check the freezer for ice build up. clean the door seals and make sure the freezer isn't overloaded. Too much food or improper sealing of the doors will make the compressor work harder in cooling down the freezer which in turn freezes the fridge part.
good luck
Phil
Sep 21, 2015 | Frigidaire Refrigerators
Refrigerator side freezing and cannot control temp.
099b99d4-9ea3-4dba-a2ca-6c92989fe8af.jpgLook and see if the air damper called a=> 5304482075 Temperature Control Thermostat is opening and closing after selecting a different temperature. This along with the termostat are what controls the fresh food section temperatures. I am here should you have questions, Thanks Sea Breeze
Apr 25, 2013 | Frigidaire Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Frigidaire refrigerator not cooling or freezing
Is the compressor running? Do you hear it running or do you feel it vibrating slightly and being warm? What temperatures are the refrigerator and freezer section at? Has the unit defrosted at all recently, and have you cleared the vents inside of food items (no blockages) and cleaned the coil and vents underneath the unit?
Jul 31, 2012 | Frigidaire Refrigerators
What's a good temp. setting for the food/beverage section
If you set the temperature below about 37 you run the risk of somethings freezing...but milk should be as close to 40 as possible, so I usually recommend a setting of about 39.
heatman101
Sep 27, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frozen food in fridge
Start with a total clean, vacuum and defrost. Unplug it before cleaning the motor compressor area. Make sure all the coils you can reach are clean. Plug it in and see what happens. If still the same - time to have a tech do pressure tests.
Mar 29, 2009 | Frigidaire FRT18G4A Top Freezer...
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Freezing fine,food area warm
I have the same refrigerator and the SAME problem. The freezer unit didn't work at first (for about a week) and then it started freezing solid with not way to control the temp. When that happened, the refrigerated section stopped working and has not worked since (two months). Help!!
May 27, 2008 | Frigidaire FRT21H8 Top Freezer...
Food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Oct 14, 2007 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
