Question about Dell Inspiron 6000 Notebook
So i've been having this consistent problem with the laptop. this isn't the first time i've posted theproblem either. in any case, here it goes: my audio and video glitches every second, the whole computer freezes for the splite second and it will go back to normal before the next second. the mouse glithces as well. i thought it was the audio problem. nope. i thought it was the video card problem nope. i've done everything i know, my friend knows, my computer geek buddy knows, to no avail. the LAST thing i haven't checked is the driver for the hard drive. somehow i need to install from DOS.... how do i do that?
  • bbaallife Oct 03, 2009
    to elaborate on the hard drive driver, there's an optional firmware upgrade from the dell website fort he 40gb hard drive. maybe it's a hard drive problem? i dunno. but i've reformatted over 30 times in the past 4 weeks
  • 3,940 Answers
The HDD controller driver for an I6000 is native to XP and not a driver you can update outside of a Windows Update. I'd first run diagnostics on the system (Fn+ Power Button) and if no hardware issues are apparent I'd backup my data and reinstall Windows. On a I6000 you should be able to restore the factory image with the CTRL+F11 keystroke at the black screen with the blue bar at the top with www.dell.com in white letters. Screen shows for about a second after the Dell Splash screen so you have to be fast with the CTRL+F11 keystoke. Again backup any important data before the image process
Posted on Oct 04, 2009
G780 started up then shut down, no indicator lights when plugged in and will not sart up
Is the ac plug loose? If you wiggle it does the light come on and off? If that isn\'t the case and it powers up then goes right off sounds like an issue with your motherboard. If the unit is under warranty I would contact Lenovo. If the unit isn\'t under warranty you should try to blow it out with can air to get all the dust out of it to see if its a simple over heating issue. If the unit still doesn\'t post, sounds like you have a bad motherboard. Let me know if you have any other questions. Good place to find more info: http://support.lenovo.com/en_US/
Just need to type in your model number which can be found on the bottom of the laptop. should be MTM:XXXX-XXX
Apr 07, 2014 | IBM Lenovo ThinkPad T400 7417 Notebook
I have a 91 chrysler lebaron. I've changed
try your regulator that does have a position in charge
Sep 08, 2013 | Cars & Trucks
What's wrong with my laptop? Screen goes black when plugged in
This is known problem with chip that regulates battery charging, and need to be fixed by experienced laptop technician.
Jul 21, 2013 | Alienware PC Systems Computers & Internet
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
I have elonex eb500 and have used it about 10 times. battery ran flat. Tried to recharge on laptop. Will not reconginse it nor will it charge or swtich back on. Please help
I had to look up what this was because I have never heard of it before. I'm going to assume it works like a laptop, unseat the battery and plug the device into its wall charger and see if it POSTS (power on self test, a PC laptop turns on and usually flashes its mfg logo while it does this) If it posts you've narrowed down the scope of the problem to the battery pack. Its possible your USB charging isn't actually drawing power I know I had a similar problem charging my Motorola flip phone on my laptops, you had to download some sort of driver from Motorola before it would accept the charge.
Dec 31, 2011 | Computers & Internet
MY LAPTOP POWER ON & OFF WHATS THEPROBLEM
Remove your battery, connect the power and try to start ur laptop. check to see if it remains on. Login to bios and see if it runs. and let me know
Dec 28, 2011 | Intel DG965RY Motherboard
My sony vaio vgn-nw320f was totally dead.i had pulled up the battery cause it could not log off.please help me.....
Most sony laptop power supplies have a power LED that indicates if the device is A) plugged in {ok it happens!}, or B) fried and not providing power to the laptop. Check this first. If the power supply is plugged in and the LED is on (usually green or red) then see if you have ANY lights on the laptop itself. Its possible that your LCD display went bad but that the laptop is otherwise running. You may see a power, hard drive or wireless network light on if the laptop works but the LCD went bad. You can also connect an external monitor to the laptop and power it up to check the LCD.
I've also seen where the battery goes bad and it keeps the laptop from booting. Try removing the battery and power up (with the ac adapter plugged in) again.
If neither of these helps, you may be looking at some kind of internal short on the motherboard which is big money. Hopefully that isn't the case.
Hope this helps!!
Jun 20, 2011 | Sony VAIO VGN-NW320F/B Notebook
I have Samsung NP-R505H laptop. My laptop won't
You say it isn't charging, but will it run off of AC power? If it isn't getting *ANY* AC power, then it might be the female end of the power jack on the laptop. If it will run on AC, the culprit is likely to be a battery that needs replaced.
May 13, 2011 | Samsung Computers & Internet
How can i make my cd770 unit display time consistently? (bought car at auction, so no remote, no manual!!)
Not sure from description if you've got it wired right, and I am assuming you have most of it working but can't get the time to stay in memory. Are you sure you have the memory power wire going to a constant power source? 1 power wire ( power with key on or in accessories mode) will run player and the other which needs constant power would be for memory and time. Almost sounds like that is missing. Some units will not run at all without both, where others will work, but not store anything such as time, and needs to be reset every time it's turned back on, if that memory wire isn't hooked up.
Apr 22, 2011 | Dual XDMR-7700 CD Player
Satellita A40 problem
Your heatsink is probably blocked.
Many older laptops run HOT and will shut down very quickly if there is no ventilation.
You can check this by shining a flashlight into the fan vent and checking it's visible when looking in the heatsink vent (or vice versa)
You can dismantle the laptop to get the dust out.
OR
Or use a can of compressed air to blow through the heatsink grilles and dislodge the dust, followed by a vacuum cleaner nozzle over the fan intake to **** as much dust as possible back out of the machine.
It may take several blow/**** cycles to clear it entirely - don't be surprised to see enormous quantities of dust erupting from the fan vent when you first use the compressed air.
if you take the second option, don't dismantle the case and it's best to do this with the machine running.
Plastic vaccum cleaner nozzles carry a hefty static charge, but as long as it remains outside the case the components will remain protected and the area where the air runs through the case is entirely shielded from the rest of the machine.
If the vent isn't freely flowing air when you've tried a couple of cycles (check with a flashlight for airflow) then the machine will have to be dismantled and the dust removed manually (I've seen accumulated dust turn into 1/4 inch thick felt blocks in some laptops and have had to write off many laptops used by smokers as they had become a toxic health hazard.).
Dismantling a laptop is not a job for a novice as it is easy to damage electronic components with stray static electricity charges and plastic case components while pulling things apart It's also possible to wreck cases by overtightening or using wrong length screws when reassembling.
Sep 18, 2009 | Toshiba P000392200 - Satellite A40, A45...
Dell Inspiron 6000 Notebook Logo
60 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
