Question about Husqvarna Garden
353 husqvarna chainsaw, floods during start process
Own 4 yr old 353 husqvarna, has spark, put new kit air/fuelfilter,plug. still will not start seems to flood during start process
    President:
  • 2,220 Answers
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
  • dontbother10
    dontbother10 Oct 03, 2009
    Your needle valves may have EPA mandated adjustment limiters.
    It should read like this.
    Cold:
    3. Pull (close - sets fast idle) choke, pull starter and listen for an attempt to start. once heard (usually two pulls)
  • dontbother10
    There may be needle valve adjustment limiters installed.
    Cold Start - should read
    3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls)
Do a complete carb rebuild. The 10% ethenol mix in our gas breaks down rubber diaphrams and needles. I think you may find your meetering needle is shot.
Posted on Nov 08, 2010
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Will not start
Do you have good compression.
If its flooding then its probably a carb issue. Strip and clean carb, check diaphrams and reset hi and low screws to standard settings. Screw both needles in and unscrew them:- H 3/4 of a turn anticlockwise and L 1 full turn anti clockwise.
Here's the breakdown for the carb. (dont use airlines to clean carbs)
Oct 14, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Cannot start husq 340 have spark but no combustion even if put gas in spark plug hole. have new spark plug
The engine may be flooded--take the plug out, turn the saw upside down, and pull the starter rapidly a few times with the throttle full on. If flooded, a fuel spray will likely come out of the plug hole. Make sure the ignition is OFF when doing this--you don't need a fuel fire! Is the spark at the plug blue and snappy (plug gap set to 0.020")? Replace the plug and see if it will run. Make sure the air filter is clean. Hope this helps!
Oct 16, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Respected Sir, I purchase a Husqvarna's chainsaw last week Model 236- 14". but I cant start it. I read manual carefully, every thing is OK. but Chainsaw can't start yet. So I request you,...
Checklist:
2-cycle oil mixed with FRESH gasoline
Spark plug wire pushed onto spark plug
Chain tight but you can still move it forward with your hand
Switch turned on
Pull the cord a few times, and then let it sit for a few minutes in case it's 'flooded' with fuel
If a new chain saw won't start, it probably has defective spark coil
Chain saws usually don't cause problems fresh out of the box, they stop working if people leave gasoline in the tank for a couple months each time.
Here's what I would do
Empty the tank of gas. Put fresh gas-n-oil into tank (not gas from an old can that was sitting there for a while)
Try starting again.
If no luck, then take it back and exchange for another.
Good luck sir.
Oct 15, 2010 | Husqvarna Garden
Hard to start, new racher455
1) Check plug & gap if that doesn't work try new plug. 2) Try cleaning air filter 3) Clean out main jet 4) Test petrol filter inside tank if dirty fit new one 5) Take plug out & fit inside HT lead & put to head of engine & see if you can see a spark when you pull the cord
Jan 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
25 yr old Husqvarna 266. starts fine, lots power, but won't idle.
I think you have exceded our level of help. Please try here.
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
You might read this thread
http://www.arboristsite.com/showthread.php?t=110858&highlight=husky+266
I searched for "Husky 266" and got many positive hits. She is a respected machine.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/9f5525102886abf488256b52001a33af?OpenDocument
HTH
Lou
Oct 16, 2009 | Husqvarna Garden
Want start
Read the warm start procedure from the operators manual.
1. Pull choke (sets fast idle)
2. Push in choke (fast idle retained)
3. Make sure ignition is on, pull (usually once on my saw)
4. Advance throttle slightly to release fast idle.
I made the mistake ONCE of not setting the fast idle. My shoulder gets sore thinking about it. HTH
Lou
Sep 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna mod 41 chain saw wont start
If checking spark make shore the out side if plug is earthed to chain saw.
Fresh clean fuel, clean fuel filter filter pull exhaust off and check piston is ok. Than check for flooding. start there.
Jan 03, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
1,756 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
