Question about Kenmore 24032\24036 Top Load Washer
Machine fills up with water and did nothing else
Someone said might be timer or coupler?
  • 5,911 Answers
This is commonly caused by a lid switch malfunction. If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models the lid switch is mounted under the washer casing by one of the lid hinges. A rod on the lid hinge is the actuator that conacts the switch. If you locate the switch and can toggle it by hand, you may only need to adjust the rod by bending it slightly.
If the lid switch is found to be defective, this is a very simple repair, that usually costs about $20 to $30 to repair yourself.
Appliancepartspros.com, pcappliancerepair.com and searspartsdirect.com usually have excellent exploded view diagrams of what I am referring to. Just type in your model number and look under the "Top and Cabinet Parts" section.
If you have questions, or require additional assistance, please let me know. Post back with a correct model number if the model number is not correct. I hope this helps you.
Posted on Oct 04, 2009
Roper model RAX7244EQ1 washer stopped after rinse
may be a bad door switch, motor coupler, clutch or tranny. have u tried running other cycles in ur timer? timer may be defective at the drain cycle, ( what happens is the time has points like a car and sometime they burn up and fuse closed, thus it will remain stuck in one position or only work in some cycles? need to do a multimeter test
Sep 27, 2014 | Washing Machines
Whirlpool LLR7144DQ0top load. Replaced coupler, now nothing works
Check list:
Motor plugged back in
capacitor reconnected
lidswitch reconnected
timer connection secure
water level hose is not pinched
She oughta take off
Service manual for direct drive and more videos
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 24, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
Maytag washer will not cycle.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool washing machine (model LLR 9245 B) does not work
If it's a top loader, the coupler is broken. It's located between the motor and the gearcase. If you put it in spin and hear the motor run, this is your problem. It drains because the pump is mounted on the opposite side of the coupler and will be un-affected
Mar 25, 2009 | Whirlpool Washing Machines
Whirlpool Top Loader LSB6000PQ0 fills up with water but that's it
you probably closed the lid to hard and broke the switch that tells the machine that it is closed. So the machine thinks the lid is open and for saftey reasons will not operate. I had the same problem. You can buy a new switch for about $10 or you can simply cuts the wires for the switch and wire them together. If you do this be warned that the machine will never know if the lid is open or closed. The machine will assume that the lid is always closed. But it will work also.
Jan 28, 2009 | Whirlpool LSB6000PQ Top Load Washer
GE Top Load Washer WLSR2000G3WW~smells like burning and wont drain
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Nov 06, 2008 | GE WBSR3140DW Top Load Washer
Front loead washer will not spin/rinse,
First, make sure that you do not overload the machine.
Sep 17, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing machine does not work
coupler or belt is out. whirlpool built machines use a coupler instead of belt. it is behind motor and pump
May 04, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
59 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
