Question about Dishwashers
Dishwasher makes a loud whining sound - Dishwashers
    President:
  • 1,304 Answers
If its a maytag
you need to fill the jet dry
Posted on Oct 03, 2009
FFBD2411NS makes loud whining noise after water is pumped out and continues until pump stops.
Thank you for your inquiry, Robert!
From the information you have provided your Frigidaire dishwasher makes a whining noise after the water has been pumped out. This could be a potential issue with your drain pump or motor. To pinpoint the issue you would need to disassemble your dishwasher and test each component and this would best be done with a certified technician. This will help you avoid personal injury or future problems. Best of luck! -Matt
Jun 13, 2015 | Frigidaire FFBD2411NS
LG LDF6810ST whine noise
-After paying an LG serviceman for a home visit, I told to refer to the manual-and there in small print-USE ONLY POWDER CLEANER. Gel and liquids make too much bubbles(thus air) in the hose producing the noise. It will take several washes-but the noise will go away!
Feb 24, 2013 | LG LDF6810ST Stainless Steel Built-in...
My Fisher & Paykel washer makes a loud whining sound when water starts to pour into the tub at start up On another note my Kitchenaid dishwasher has started being very loud while running and it...
Hi, I am having the exact same problem with my washer and my dishwasher. I have a lot of mineral deposits in the dishwasher, too. I am guessing it is a hard water problem, but am interested to hear whether that is a factor in your problem?
Dec 09, 2010 | Kitchen Ranges
A loud whining noise from motor area...diminishes during cycles but resumes at times.
it sounds like to me the water pump on the bottom of the dishwasher sounds like its getting tired the bearings are going an as the water gets stronger its lubricating the beering making it dimishe
Jul 10, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
The dishwasher makes quite a loud sound, not grinding but more like a pump impeller whine when the washer is started and during washing.
It could be a motor with bad bearings. But to check you need to remove washer and take outside or in garage. Put machine on it's "back" and take pump apart and look for obstruction. If you are mechanically inclined this is EZ!
Jun 10, 2010 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool Dishwasher Model: GU2500XTPQ3 making loud whining noise
It's most likely coming from the wash motor bearings. Based upon the age of the dishwasher it might be time for a new one. Although it can be fixed by replacing the motor. It's usually easiest to change the entire sump assembly with the motor. You will have a new wash system. Part number W10782773 Dishwasher Pump Motor Part Number 8535150 Sears PartsDirect
Feb 22, 2018 | Dishwashers
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Feb 23, 2008 | Dishwashers
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
