Question about Dayton Electric Space Heater - Model D-F79
Dayton model # 3E837
This heater has fan running as well as ignition with out warm up time...I need to find out why ? the problem is : ether fan runs and no ignition ! or ignition is lite and fan dont run. both sensors are good ! I think it is a wireing probelm. Im trying to help a friend that does not know about wireing but has switched wires while tring to correct the problem......if you can help I thank you very much ....michael
  • phlipp Jan 09, 2009
    I have a 3e837 also but I need a wiring diagram, could you help?
    Sergeant:
  • 288 Answers
When someone has altered the wiring, the only thing to do is get the wiring diagram, undo what someone else has done, then you can start diagnosing. I wish I could help more but unless its wired right you are kinda stuck.
Posted on Dec 25, 2007
How to light a pilot light and find it on a suspended Dayton 3e837 unit?
If this heater has a standing pilot locate the gas valve on the lower back of the heater. Follow the 1/4'' aluminum tubing into the burner compartment. At the end will be the pilot assembly. Usually there is some type of access door or the bottom panel on the heater comes off or swings out of the way
Jan 02, 2018 | Dayton Heating & Cooling
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
I am having trouble getting my Dayton Portable Oil fired Heater Model # 2E218E to keep running.
May be the primary control if you already replaced the photocell. Make sure the photocell is in direct line of sight with the flame.
Jan 04, 2014 | Dayton Heating & Cooling
Dayton Model 1VNX5 Kerosene clicks like crazy but won't light
I have the same heater with the same problem. I took the top cover off, removed the ignitor and bent the probes slightly closer. Use two needle nose to prevent breakage of the holder. It has been working fine since.
Dec 13, 2009 | Dayton Heating & Cooling
Why does a pilot light go out,but the fan keeps running?
some heaters use a timer to bring fan on as opposed to some which use temp
Feb 24, 2009 | Dayton (4LX41) Heater
I have a Dayton gas heater Model 3E225
Does the main blower fan kick on? Also, if the heater is vented outside via a flue pipe, there may be a small (about 3 or 4 inches in diameter) vent fan that kicks on to ensure the exhaust fumes are evacuated through the flue pipe. If there's a problem with that fan, the burner won't light either.
Nov 20, 2008 | Dayton (3E379) Heater
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Nov 01, 2008 | Dayton Gas Furnace Heater
Heating & Cooling Logo
250 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
