Question about Garden
I have a poulan weed eater gti 19 and need to know how to remove the hub., so as to replace it. I need to find a operators manual
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
bbreton
  • 437 Answers
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Posted on Feb 25, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
alpug
  • 1961 Answers
SOURCE: I need to down load the ower manualfor troy bilt
here is the manual. Just click the file to download instantly.
1. 769-04481_TB539E_Operators_Manual.pdf
Please don't forget to give this answer a four thumbs up rating.
Thank you for using Fixya.
Alp
Posted on Sep 25, 2010
SOURCE: Tryingto replace my troy built weed eater's head
clean grass off between shaft and the top of the head. hold weed eater still and turn the head, looking between the shaft and the top of the head. There will be what looks like a hole. Place something there that will keep the shaft from turning, then twist the head off.
Posted on May 25, 2011
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Ss30 ryobi weed eater fuel ratio
I work with weed eaters and mowers. Weed eater fuel ratio is normally a 40:1 ratio. That usually all weed eaters fuel ratio.
Sep 11, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I need a manual on polan chainsaws
You don't give us model or serial number. IPLs can be downloaded here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The operator's manual is included in the IPL (not pictured) and must be purchased. GL
Lou
Sep 17, 2009 | Poulan Garden
Can't get weed eater started. Have an older weed eater brand. Fuel is getting to engine, but can't get it to start. How do I adjust the carb to get it to start. I have cleaned everything out and have the...
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Sep 17, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Jun 13, 2009 | Poulan Garden
My te 475 weed eater wont start
Check the on-off switch? Try disconnecting the switch and see if it starts. If it does, replace the switch.
May 18, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
