Question about HP LaserJet 1000 Printer
Paper feed my hp laserjet 1000 does not pick up the paper anymore. it goes through the motions when you try to print something, but it won't pick up the paper. is there a piece that wears out over time? perhaps something i can easily replace?
  • HP Master
  • 1,113 Answers
Yep the paper feed roller wears and will need replacement (open front cover in centre of machine tabs on either side it just clicks out.
should also change sep pad (multi feeds)
Here in LINK to purchase items pic below
Posted on Dec 21, 2007
My HP LaserJet P1606 does not pick up paper anymore. I grinded somekind of gears, and all of a sudden the pickup roller and associated bar does the rotate enough to pickup the paper when printing.
Open the front and remove the toner cartridge. Turn the paper feed roller by hand until it clicks and goes slack. This is the rest position. Try it again. It doesn't sound good that you said you 'grinded some gears'. You may need HP professional service or a new machine.
HP LaserJet Pro P1606dn Printer Software and Drivers
Nov 17, 2017 | HP Office Equipment & Supplies
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
My HP 1210 goes through the motions but will not pick up the paper. I have removed the back and moved the "wheel" as suggested but nothing is happening????
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
Paper jam in HP Laserjet 4V
remove the cassette you can see two or 3 roller down the printer clean that roller and try.....
Oct 07, 2009 | HP LaserJet 4mv Printer
Our HP laserjet M2727nf does not feed the paper to print anything
just clean paper pick up roller whit wet cloth or alcohol...you can do this for ADF pick up rollers too if someday have the same problem whit ADF. Good Luck!
Oct 05, 2009 | HP Laserjet M2727nf Multifunction Printer
Printer will not pick paper
As a test, please try to print something using paper in the manual feed bin.
If that works, remove the tray, take all the paper out, verify the springs on the tray are working again then reinsert the paper and tray and try again.
Thank you.
Oct 04, 2009 | HP LaserJet 1320 Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
My HP laserJet 2200DN doesnt feed paper when printing.
it could be hardwre problem.. you need printer technician to replace some broken parts
Aug 25, 2009 | HP LaserJet 2200dn Printer
Paper keeps feeding through and won't stop
Two possibilities;
One you have a messed up print job trying to print and when you turn the printer on the job just starts over.
Two the clutch that stops the pick roller is bad and the roller just keeps turning.
Unplug the machine from the computer and turn it off unplug power for awhile turn it back on not connected to the computer. If condition remains it is the clutch.
If condition goes away delete print jobs and re connect printer.
Hope this helps
Mar 26, 2009 | HP LaserJet 1300 Printer
Open Questions:
See all HP LaserJet 1000 Printer Questions
HP LaserJet 1000 Printer Logo
269 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
