Question about Sony MHC-DP1000D System
Sony MHC-DP1000D Push Power Protect Problem
I have Sony MHC-DP1000D Music system, now when i switch on the system, Push Power Protect Messsage appears on screen, Please Help Me..!
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: my sony mhc-s9d goes to 'push system protect;
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
How To Remove Push Power Protect To My Sony mhc-dp1000d?
You can't. There is a short in the amp that needs to be repaired before the unit will power on normally.
Mar 07, 2013 | Sony MHC-DP1000D System
HI I HAVE SONY MHC-RV900D WHEN I SWITCH IT ON IT SHOWS PROTECT PUSH POWER. HOW CAN I PLAY MY SYSTEM AGAIN.??
Welcome to FixYa
Do Following...
  • Turn off the System-Turn it off for a while
  • Then turn it back on.
  • Still Problem, Turn Off system and Check the Speaker Code
  • RESET the system .
  • Remove all the connections, leave it for 24hours and then connect it up again
To Reset
  • Unplug Power Code
  • Plug it back again
  • Press Stop , Enter and Power button at Same time
  • Press Power Button to Turn on it
For more Here is the Guide for your Product Click here
Still have Problem The protective device on the amplifier has been activated because of short circuit. (“PROTECT” and “PUSH POWER” flash alternately.) Turn off the unit, eliminate the short-circuit problem and turn on the power again.
Hope you Got a Conclusion..Thanks for Contacting FixYa...
Jun 15, 2010 | Sony MHC-GX40 CD Shelf System
Protect push power
audio amplifier IC fried need to be replaced
Jun 01, 2010 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Protect push power
you have wires touching. did you drop anything in your radio? water, medal's?? etc..
Dec 19, 2008 | Sony MHC-RG30T Shelf System
Sony mhc-7av push power protect
Maybe the audio amplifier IC damaged and need to be replaced good luck
Dec 17, 2008 | Sony LBT-LX50 CD Shelf System
Disconnected optical input cable
Optical Input connector will go to CN601 of DSP board right under DVD mechanism.
See picture to find DSP board in MHC-DP1000D Hi Fi system.
Oct 29, 2008 | Sony MHC-DP1000D System
Displaying ' protect power ' on the screen.
Replace the audio amplifier IC because are damaged
Aug 29, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
