Question about Tippmann A 5 Standard Paintball Gun
I need to find the parts for the tippmann a5 urban warrior paintball gun
    Problem Solver:
  • 8 Answers
Tippmannparts.com is better they have all the replacement parts for it. or just call tippmann up if you need something.
Posted on Dec 14, 2009
    Problem Solver:
  • 8 Answers
Home page | Special Ops Paintball SPECIAL OPS - A-5-A2 COMMANDO EZ-KIT. Regular Price: $ 79.95 ... Special OpsPaintball is a proud sponsor of the Living Legends scenario paintball game. ...
shop.specialopspaintball.com/ - Cached - Similar
Forum Brigade Tippmann A-5 Upgrades Gear Vests Articles Sick Deal Tippmann X7 Upgrades MarkersThey got it everything for an A-5 and they are inexpensive and ship quick!!!! ---WETWORK_SAT-SILVERBACKS ASSAULT TEAM
Posted on Oct 04, 2009
My a5 has no pressure with my flatline installed, and works fine with stock barrel... pleASe explain
Have you chrono'd the gun? This test velocity. This makes no sense unless your
gun is actually shooting VERY slow. In that case the way the flatline works, the ball rolls thru the barrel,
would really slow down a ball passing thru. That is my bet, low velocity. I use the same gun.
Adjust your allen screw in to make more pressure and try the flatline. Man I love the flatline with
an e-grip. Scares the **** outta the long distance players!
Here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Feb 18, 2011 | Tippmann A 5 Standard Paintball Gun
Hello, I have an old Tippman A5 (about 5-6 years
You will have to buy a different barrel for the A5, I would suggest ansgear.com, rockstartactical.com, or ebay. Make sure that you get the right threads along with an apex capeable front. I would suggest the sly carbon fibur barrels, or get a autococker barrel and a lapco adapter for your A5. Hope this helps if you have any questions just let me know.
Jan 18, 2011 | Tippmann A 5 Standard Paintball Gun
When I try to **** my gun, the valve makes a cracking noise, and doesn't move.
Sounds like it is put together wrong. Take it apart and follow the diagram to put it back together
or head to your local shop and have them help you. Make sure to oil the internals.
Jan 06, 2011 | Tippmann 98 Custom Act Paintball Gun
Keeps blowing o rings
If you are using CO2 switch to air. Also make sure the velocity adjuster isnt running
at the highest rate. Which specific O-ring are you blowing out?
Jan 02, 2011 | Tippmann A 5 Standard Paintball Gun
I have an a5 paintball gun with electronic trigger, when i hook it to air and pull the trigger, the hopper is not moving!!!
On the A5 the hopper or Cyclone feed is powered thru a small tube on the feeder side
of the gun. Make sure that tube is connected and if so, pull it off and see if air is flowing
thru it when you pull the trigger. If not, the internal passage may be blocked. Tear down
the gun and clean out the obstruction. If there is a pulse of air coming out the tube when firing
then it may be the Cyclone feed mechanism. Just unscrew the 3 phillips head bolts
under the Cyclone and observe the air driven gear drive. Air up the marker and see
what is moving or not moving. Complete replacement upgrade Cyclone gear drives
are available that say they increase performance if you cant get it moving.
Here is your manual
Sep 25, 2010 | Tippmann A 5 Standard Paintball Gun
Paintballs will fall out of the barrel of my tippmann 98 custom, randomly when the gun is not being fired. I am not sure how to fix this, or if it can be fixed. Mechanically the gun fires and aims great....
Get another ball detente from ebay, this one is the cheapest one I could find.
http://cgi.ebay.com/NEW-TIPPMANN-C-98-BALL-DETENT-A5-BALL-DETENT-/370469346400?pt=LH_DefaultDomain_0&hash=item5641b19c60
Jun 26, 2010 | Tippmann 98 Custom Act Paintball Gun
A5 freezing up
There might be a couple of reasons for the malfunction. It is my experience that the upgrades made for Tippmann not always improve the performance of the guns, in fact they may cause problems like the one mentioned. I would try to switching your set up back to see if the problem continues and if it does make sure you have a fully loaded tank and that the internals on your cyclone are functioning correctly.
May 18, 2010 | Tippmann A 5 Standard Paintball Gun
I took apart my magazine to clean it and now I can not remember how to but it back together.
The A5 is a very compact and simple gun, I am attaching a link to the manual which shows in the detail the procedure.
May 08, 2010 | Tippmann A 5 Standard Paintball Gun
How to install g36 body shroud onto a tippmann a5. any bolts and screws, tools and etc? thanks for your time.
Forum Brigade Tippmann A-5 Upgrades Gear Vests Articles Sick Deal Tippmann X7 Upgrades Markersgo to markers and you can see the shroud mounted youll need the hex screws you can buy then here.
Sep 16, 2009 | Tippmann A 5 Standard Paintball Gun
How to remove a responce trigger from tippman a5 paintball gun
To remove the response trigger you need to first remove the grip frame. Remove the piston and replace the fitting that supplies air to the piston with a plug. you can find this at any local paintball store or online at www.badlandspaintball.com. If you can't find this plug than you can leave it open as it is not under pressure all the time only when the marker is fired, you will waste air this way. Good luck
Apr 01, 2009 | Tippmann A 5 Standard Paintball Gun
Tippmann A 5 Standard Paintball Gun Logo
154 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
