Question about Kitchen Appliances - Others
Need a manual on how to program GE 5123 wall timer
  • Anonymous Mar 23, 2014
    Need instructions on how to program
I replaced the unit as it appeared to be defective.
Posted on Oct 05, 2009
PROGRAMING SWITCH TIMERS
1) Copy following links to help identify timer and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Add a comment and describe timer in detail, including what the timer does, and what buttons appear on timer face, and location of each button.
Feb 15, 2013 | Intermatic Inc. EJ500C Digital Wall Switch...
How do you open the GE digital Timer to program
Timer is not identified.
Add a commetn and describe timer.
If you have in-wall timer, the little door on front of timer lifts up.I tested this timer and the door is poorly fit on some of the timers and has to be pried up with a small screwdriver or key.
Oct 04, 2011 | Hardware & Accessories
I can set the date & time and sunrise and sunset; however, the instructions to program are obscure to me. I want it to come on at dusk and go off at a set time.
1) Question posted under ST01C
Open following link for ST01C instructions with programming illustrations, plus wiring illustrations and battery information.
http://waterheatertimer.org/ST01C-program.html
2) The ST01C cannot be set for on-at-dusk and off-at-programmed-time.
3) If you have different timer than shown above, then add a comment with description of timer buttons for possible identification.
4) I have not tested the following timer, and it may be same as all other in-wall timers, but it is possible that the new GE 15312 sun-smart timer can be set for on-at-dusk and off-at-programmed-time. BUT I am only reading the instruction manual for a new product, before people write the company and then the manual gets changed.
Wiring for this timer is more complicated that ST01C
http://waterheatertimer.org/pdf/GE-15312-sun-smart-Manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15312
5) There are numerous outdoor plug-in type timers that offer on-at-dusk, and then off 2 4 6 8 hours later.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
6) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 06, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Installed several GE smart digital timers around the house: for lights over garage, front door, court yard. They are model 15086. The units work in timer mode as desired. I would think...
15086 timer:
Pressing door will override timer setting and manually turn switch ON-OFF.
Press door or open timer door, and press any of 4 buttons located in corners.
You know information posted so far:
However, you are moving the small switch from Timer to OFF.
And when switch is OFF, the override does not work because circuit is OFF.
You want a timer that can switch programming OFF, and not switch circuit OFF, so that device toggles between timer and ordinary switch.
Looking at timers on the market today, I cannot think of any in-wall programmable or box timer that does what you want. Each has manual override that reverses timer function, but when you set timer to OFF, the circuit is OFF.
http://waterheatertimer.org/Programmable.html#Aube
Plug-in-type timers have override button that turns programming off, and then you can operate table lamp normally with the lamp switch. But in that case, the lamp has separate switch that operates outside of timer functions.
GE 15070 24-hour mechanical timer could do what you want:
http://waterheatertimer.org/images/GE-15070-mechanical-timer.jpg
In this specific case, when you wanted to operate timer like a light switch, you would move all the pins inward, and then use the on-off switch. The problem with this idea is the pins are tiny, and you need very good eyes or a light-source and small tool to continually adjust pins.
See GE timers and manuals:
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 07, 2011 | UPM Programmable Wall Switch Timer
My GE Smart Digital timer won't shut off at the assigned time, but it will shut down manually.
I am guessing that you have digital in-wall timer GE 15071 or GE 15086
To identify timer for sure, see images at following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Manual for 15086
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
If this is new timer, the problem could be a couple things.
1) Circuit has electrical problem that is affecting timer electronics.
Use circuit analyzer from Home Depot electric department and test any receptacle on same circuit breaker as timer.
2) event1 ON was programmed but event1 OFF was not programmed. To review events, press Prog button once to see event1 ON and press Prog button again to see event1 OFF. When review is complete, press clock key to return to current time.
3) event1 ON and event1 OFF are programmed with conflicting day schedules
4) event1 and event7 have conflicting schedules
If this is new or old timer:
5) Timer needs to be reset because of internal glitch. Press and hold reset button for a moment and timer display will start flashing 12:00 am MO
6) These timers can go bad any time. I test timers and 4-6% arrive defective, and most quit after couple years, but some can last quite a while. This is why I suggest using a circuit analyzer to check if circuit is causing difficulties.
Dec 26, 2010 | Hardware & Accessories
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
http://waterheatertimer.org/Aube-timers.html
Utilitec 0192773 with 7-day and astro dusk to dawn
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
Woods 59018 in-wall
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
Dec 17, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have two black wires and a ground in the switch box. Please advise on proper method to install. thanks
If you have ST01C timer, then open following link to see correct wiring diagram for single pole switch replacement:
http://waterheatertimer.org/ST01C-program.html#ST01C
For other timers including Swilight, GE, Leviton, Brinks, Grasslin, Stanley, Utilitec, Westek, Woods, Tork, UPM, Paragon, Hagar in-wall timers: Open following page for correct wiring of GE in-wall timers.
Same wiring steps are used for in-wall timers listed above.
If you are wiring Aube timer.
For all other timers, add a comment with in-focus photo of your timer for correct identification and possible assistance.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Also take advantage of fixya expert assistance live.
Jul 05, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Kitchen Appliances - Others Logo
675 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
