Question about Epson Stylus CX6400 All-In-One InkJet Printer
Printer error...see your documentation..... documentation says turn off then on to remove error.. if that doesn't work call service if necessary (documentation claims printer parts are beyond life)My question is-is it worth repairning or just get a new printer?
SOURCE: service life has ended on my epson stylus r320 photo printer
I have had a R300M for a while now and had a few cartridges in it. (Mostly Compatible Cartridges not OEM) Recently a message came up on the screen 'parts inside your printer are at the end of their life' and the printer refused to work!
After searching the web it appears to be a waste ink counter, but I could not find any info on resetting it.
Tried pressing different combinations of buttons on the printer and success. (Found Ink counter reset)
Press and hold 'stop' 'maintenance'(ink button) and 'power' buttons for about 10 seconds,(while printer is on) a message will come up on the screen saying counter is reset and to turn off.
Thats it, turned my printer back on, and all works fine again.
I hope this helps R300/R300M owners out!
(Also I have email into Epson Support, can't wait to hear what they say the problem is for the fix!)
Good Luck,
Steve H.  :-)
Posted on Jan 06, 2008
SOURCE: Parts inside your printer are at the end of their service life. See your printer documentation
I FOUND IT! I KNOW HOW TO FIX:
This saved my printer:
  1. Unplug the power and USB cables from the printer.
  2. Prepare your work area by putting scrap paper down. Have somespare, just incase. You may also require tissue paper. It is alsorecommended you use protective gloves as the ink will stain your skinfor quite some time. Its really messy, trust me.
  3. Look at the back of your epson c46 there will be a "door" a small square that removes. Take it off.
  4. There will be 1 or 2 "spongey things" inside your printer, remove them. Sounds easier than it it. Can take up to half an hour.
  5. Take the scrap paper with the pads on to your sink, turn on the hottap and hold each one under the tap using the pliers until the waterruns clear. If you have protective gloves on it may be worth squeezingthe water out also. Don't use soap ect.
  6. It is recommended that once you have done this, you let them dry.
  7. Now return the pads back into the printer.
  8. Plug in the USB and power cable and turned it ON. (Yes the lights will still flash)
Part 2:
  1. Download and install the SSC Service Utility for Epson Stylus Printers.
  2. Select your printer and model number (There is no Stylus C42 UX, so select Stylus C4x), then close the window.
  3. You will see a SSC Service Utilitiy icon (it looks like a printer) in the system tray (next to your click), and LEFT click.
  4. A menu will appear, from here you can click on “Protection counter” (its a red cross), then “reset protection counter”. You might have to do this a few times..
  5. Turn the printer power OFF, wait 10 seconds and then turn it back ON.
Good luck guys!!
Posted on Apr 18, 2009
websnail
  • 419 Answers
SOURCE: service required epson stylus dx 4850
Like most Epson inkjet printers this message is to warn you that the waste ink pads are expected to be in need of replacement soon.
The options open to you are:
  • Get the printer serviced by a registered Epson printer tech. Usually costing as much, if not more than the printer
OR
  • Reset the waste ink counter using a suitable utility and then installing an external waste ink tank to collect the waste ink.
The latter is much more cost effective and you can either source the parts for a tank yourself of purchase one of the kits available on ebay or in a number of other stores including my own :)
The reset utility is available via mediafire but you MUST scan it thoroughly for any trojans, virus or other malware before you attempt to use it. Then, if all is clean, check the instructions in detail and follow them carefully.
All in all, it's about half an hour to an hour of your time to complete this for the first time.
Hope that lot helps.
Martin
Posted on May 20, 2009
Respected Sir,
While printing In Epson Stylus Photo R230 Printer, the print out of black portion of any text document or imges become white and a message displays : Parts inside your printer are at the end of their service life.
Please give me solution and oblige.
Thanks,
Asim Roy
e-mail : roylaser@rediffmail.com
Posted on Aug 02, 2009
Spooler service is not running Model Z32
There are several ways to resolve printer spooler error, probably because there are many variations of this error.
The error caused by faulty software can be resolved by deleting all the information found in the directory.
Thereafter, navigate to the Control Panel, click on Administrative Tools and then services icon.
Find the service labeled Print Spooler, highlight it and restart the process. If that doesn't work, the program might be corrupted.
Click on start, then Run. Search for the document labeled services.msc, and this will trigger the opening of another window.
On this window, scroll down and click "Print Spooler". Check its setting and turn on automatic mode.
Click Okay, and restart the machine. If you're lucky, this might be all you have to do.
Still doesn't work? Navigate to the Add/Remove Programs screen of the Control Panel.
Find the all the software responsible for making the printer run including the drivers, and uninstall them. Be sure to be thorough about it, or the problem may not be solved.
Download the latest copy of your printer's software from the manufacturer and reinstall it.
May 17, 2011 | Lexmark Office Equipment & Supplies
Error message spooler subsystem app not working
Apr 12, 2011 | HP Photosmart C4480 All-In-One InkJet...
Printer error
This means see the document you are printing or install it again
Nov 19, 2009 | Epson Stylus RX580 InkJet Photo Printer
It reads Printer Error - see your documentation
this means your printer waste pads are full and the printer needs to be reset for it to work again or it can just be reset
Sep 25, 2009 | Epson Stylus Photo RX500 Printer
When turning the power on to my Epson CX6400, the following error message comes up: "Error: Printer Error -> SEE YOUR DOCUMENTATION AND CALL SERVICE IF NECESSARY." The little "!" exclamation point...
Sounds like the ink counters need resetting (it happens with other printers as well)
Go here for more info as the prog supports your printer
http://www.ssclg.com/epsone.shtml
Jul 17, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error see your docmentation and call service if necessary
Please follow the steps below to resolve your issue.
1) Turn off the printer.
2) Lift the scanner cover.
3) Toggle the transportation lock five times, ensuring that it is in the unlocked position, towards the back of the scanner.
4) Turn on the printer, and the error should be cleared.
Jul 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Printer error
Does the printer print? and does the scanner scan?
Nov 02, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
107 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
