Question about Standard (CRT) Televisions
MagnavoxTV model number 19PRC2 3121, serial number 43824079
A loop promotional piece is now running on the tv set and I am not able to interupt the run or turn off the set. It is an older set but has been doing fine until now. What, if anything, can be done to restore sanity?
5 Suggested Answers
  • 579 Answers
SOURCE: Standard TV-Auto shut down
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
Figure on replacing the flyback transformer.
However, my experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like PTS Electronics at
Hope ya fix it!
Posted on Feb 04, 2008
  • 1694 Answers
SOURCE: running screen
No vertical sync lock caused by bad caps on PIP module..
REMOVE module.....solder 22mf / 50v NP capacitors
on bottom of PC board ..VP connector pins 5 to 11 and 7 to 9.
Picture will be stable.....forfeit use of PIP box feature.........T.
Posted on Feb 08, 2008
  • 105 Answers
SOURCE: I have an older model
try to check and change a few capasitor below reading, resolder the conection and try to check the yorkcoil (coil beside the picture tube) becarefull to open please mark averything went to open it
Posted on Dec 08, 2008
  • 377 Answers
SOURCE: TV turns on and off while watching.
re solder the Electronic semiconductor , IC Specialy in power supply side. cold solder might the cause.
Posted on Jun 07, 2009
  • 13 Answers
SOURCE: The TV is Model number
Overheating circuit board may be, the logic board may need some capacitor or transistor replacements
Posted on Mar 01, 2011
0 characters
1 Points
How do I get my color back and closed caption off my TV. I have my Phillips Magnavox TV serial number TS2544c122/ The remote to controled with our dishnet one. I need to get my color back and closed
Sounds like you might have switched display from pal to NTSC or vice versa.this is usually the first thing that causes color to drop out.if not you will need to go through menu settings to check if you have rgb or similar color controls that are not set correctly.i assume you have already checked the saturation has not been turned down.sometimes the remote buttons can stick down or be under a book or cushion which will alter tv controls without your input.
Jan 03, 2015 | Standard (CRT) Televisions
How do I get a manual for an old MagnavoxTV?
Please go to this site and scroll down the page for the user manual of the model you need.
Sep 01, 2014 | Standard (CRT) Televisions
my Sylvania gps navigation system stop working. can anyone offer some advice what to do? model sgpd432 serial number 100902555. my system is stating it can not find the gps program! and please set gps path in file manage.
Jan 29, 2012 | Sylvania Standard (CRT) Televisions
Old JVC television model AV27220, serial number 10616951, chassis number A67, manufactured May 2001 - I lost connection with my CD/DVD player (Sony model DVP-NC615, serial number 1165211) for no...
The outputs from the dvd that you are describing are that of line level and not you don't need to tune the tv to just need to put the tv on the video source setting(video1,2,3 etc..)..if you have the remote..there should be an input buttton or a source button
Jan 07, 2011 | JVC Standard (CRT) Televisions
Lost the remote for my toshiba tv model 27a32, need the model number to replace the remote (prefer to get a toshiba remote rather than a universal)
The model number will be on the back of the tv. You'll have a model number serial number and a few other numbers. But for the price of a factory remote you can get a really nice universal....
Dec 07, 2010 | Toshiba 27A32 27" TV
Is this tv model number HD-compatible?
that tv has 3-inputs digital comb filter
component video input
tv,vcr,and dvd
and also a S video input which can be connected to hp for video transfer.
yes it is compatible.
Apr 07, 2009 | JVC AV-36D303 36" TV
Do Ineed a converer to receive digital tv signals ?
Your TV has an ATSC tuner and will receive over-air HDTV reception available in your area with an antenna.
Jan 27, 2009 | Toshiba CZ27V51 27" TV
Running screen
go to menu then horizotel set it so it wont have lines
Feb 07, 2008 | Standard (CRT) Televisions
TV will not turn on.
A high pitched whine is most of the time the power supply trying to run, but it is being loaded down from a short somewheres in the set. Sometimes a resistor on the CRT board will open and make the set shut down right after start up, sometimes the horizontal output transistor causes this problem, almost any circuit for that matter can cause this problem. Good Luck
Jun 14, 2007 | Philips TP3681C 36" TV
Hitachi Multisystem TV model # C2980FS ..not powering on
First off you gotta tell us whats the right model and make as you have two listed here and both of these flybacks are avail. trough The parts are not listed online but get the toll free # or leave a message for them to get back to you. Now A flyback is not a user replaceable part for starters. It is soldered in and theres very high voltage inside these sets even after they are unplugged, and its not adviseable to replace a hi-voltage part in a set, unless you know the issues involved with replacing such parts. Good Luck
Jun 17, 2006 | Toshiba 35AFX54 35" TV
Standard (CRT) Televisions Logo
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
