Question about Acer Extensa 4620 Notebook
Need to remove and cleankeyboard - Acer Extensa 4620 Notebook
  • 1,498 Answers
Your keyboard may need cleaning, but disassembling a notebook or laptop may cause you more problems when you try to put it back together. Without the proper training on that specific model, I'd advise against it.
There is a protective membrane on the keypad to keep dust and moisture out of the interior.
If it under warranty, opening it up will void it.
If its malfunctioning, an external k/b is an alternative.
But, disassembling it up is a can of worms you don't want to open.
Best regards
Mike
Posted on Oct 03, 2009
  • Justin Case
    Justin Case Oct 11, 2009
    Hey there AR,
    A little follow up, especially after that hideous rating I received.
    Just curious, did you go ahead and take it apart anyway?
    Give it a good cleaning?
    Get it back together yet?
How do u replace lower control arm bushes nissan navara d22 duel cab 4wd 1997 , do u need to drop torsion bar and if so what's the best way to do this
to remove lower control arm bushings you need to remove control arm from vechicle have control arm bushings pressed out.you need to remove disconnect torsion bar,remove shock absorber,disconnect stabilizer bar link, remove axle half shaft, remove the lower ball joint, remove control arm mounting bolts, then remove lower control arm.
Nov 24, 2012 | Cars & Trucks
How to remove a automatic transmisson from a 1993 ford escort
you need engine support fixture or engine lift crane support engine when you remove transmission.you need all basic tools need floor jack and 2 jack stands.you need a haynes repair read chapter transaxle removal, you have right many things to move remove transaxle this is not a easy task you need a repair manual read entire procedure before removing transaxle, if its your first time you will need a helper.
Nov 12, 2011 | 1993 Ford Escort 4 Door
How to remove window crank?
first you need to remove all screws in thje door panel then remove the crank handle with a pick or special tool to remove the clip that holds the crank arm on. then remove the panel and you will find a plastic cover that cover needs to be removed to access the window regulator. once there you will see screws which hold the window those need to be removed so that you can remove the window crank.
Jan 15, 2011 | 2000 Jeep Wrangler
Hi i have a laptop advent 8109 i need to open it
Remove panel at the back, remove keyboard from prongs at the top, remove HDD, remove screws holding down the laptop, remove heatsink, remove fan, remove ODD connector, lift out motherboard at an angle. Its really something that needs to be shown, but thats the order in which you need to do it. If you can figure out the "in-betweens", you will be on your way to a cheap repair!
Jun 18, 2010 | Advent Netbook
I need to remove the dash in 2005 chevy silverado
to remove the dash in your truck you will need to dedicate about 8-10 hours. first start with removing your kicker panels, then the plastic covers on your a-pillars. remove the bezels around your instrument panels. you should be able to see some black screws by now, they should be a 7mm some may be a 5.5mm start removing all the screws you can. next you will need to un plug all of your switches, airbags(yellow plugs), 12v accessory plugs, be sure to remove your battery cables before unplugging all of this. your dash cover is a pain to remove so be patient with it or you will break it easily. to remove your dash cover remove the screws in the front and you will have to pop the back of dash up then remove. next you will need to remove your steering wheel/column this is easily done however you will need alot of extensions for your ratchet to do this. after pulling your steering wheel/column remove the four screws by your windshield to remove your sub-dash i believe they will be a 10mm. remove your sub-dash. next you will need to remove the dash support frame, you will need a 15mm and a 10mm socket to do this, i believe there is 5 bolts holding this on. if needed you can remove the black box that holds your fan heater core blender door cab filters and etc... to do this you have to remove the ac hoses coming out of your dryer can going into the firewall, this will bleed out all of your freeon, next remove the heater hoses, now there are 7 bolts or nuts to remove on your firewall, when you remove those you can pull out the black box.
Oct 09, 2009 | 2005 Chevrolet Silverado 1500 2WD
How to remove bearings on 1998 gmc jimmy axle shaft bearings and pinion bearing?
if diying and axle bad replace the whole unit from salvage or rebuild shop.if changing the bearings its a lot of work and you will need some special tools to put back together .first you need to use a lift or again have to remove unit from truck, disconnect battery remove drive shaft,remove pinion nut need large breaker bar loosen bolts to rear cover drain fluid remove cover have someone push axles toward center remove c locks slide out axles best way to remove bearings is slide hammer bearing removal unit remove rear [gears] dont loose shims will see pinion bearing bearing remove and replace now 2 put it back.need shim package, red lead, 4 ring and gear mesh adjustments ,,
Jul 07, 2009 | 1997 GMC Jimmy
Driver side mirror installation (and removal of old)
Inside the pull cavity on the window switch bezel there is a cap in the bottom of the cavity.Remove this cap and there are 2 screws there you need to remove,then remove the window switch bezel.
There will be a screw there in the door panel where the bezel was covering up,remove this.
Under the door handle you will see a small square cover,remove this and you will see another screw you need to remove.
You will see 2 more screws at the bottom of the panel you need to remove.
Then lift up on panel and remove.
You will then see 3 nuts holding mirror on,remove these and remove mirror.
Apr 03, 2009 | 2003 Lincoln Aviator
Need help on get n a key switch out of a 93 buick regal gran spor
remove steer wheel with puller. u will see black cover remove 3 tork screws.remove. next u will need a special tool push dowd on plate . remove clip in center. remove plate.. remove bolt for lock cly. turn key lock will slide out
Nov 15, 2008 | 1994 Buick LeSabre
1991 Cutlass Ciera
you need to remove the steering wheel with a puller then remove the screw holding the blinker lever now remove the three screws holding the directional switch you will need a special tool to remove the steering lock ring if you don't have this tool you can not remove it after you remove the ring remove the buzzer contacts and remove the screw for the ignition cylinder and put in new cylinder
Oct 18, 2008 | 1991 Oldsmobile Cutlass Ciera
Acer Extensa 4620 Notebook Logo
85 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
