Question about Reliance & Drain Valve for Gas Water Heater
I need to replace the tp valve on my reliance gas 501 water heater...the model is 5 40 nort971...what is the shank size of the valve?
  • 129 Answers
You will want to use the long shank temp-preasure relief valve.
Posted on Oct 04, 2009
Reliant 501 Natural Gas won't stay lit
Reliance water heater?
Thermocouple is good if the pilot stays lit continuously.
501 is older model. Unknown if this unit has FVIR protection and sealed combustion chamber or open air intake on front of unit.
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
With FVIR protection:
Get more fresh air to the unit.
Clean the flame arrestor screen.
Test and replace the thermocouple:
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
Inspect and clean burner and combustion parts
Test gas pressure, bleed air out of gas line.
Replace gas control valve.
Test draft air by lighting match and see if smoke is pulled into the vent pipe at draft hood on top of tank.
Aug 20, 2012 | Water Heaters
How can I find out what the Energy Rating is on my Reliance 501 w/h?
Reliance is AO Smith company.
http://www.reliancewaterheaters.com/prod/gas.html
http://waterheatertimer.org/Water-heater-manufacturers.html
1) Reliance does not post the 501 manual any more and I've written and asked for that manual, and they sent generic manual. Model 501 is both gas and electric.
2) That tells me the old energy factor is probably lower than .54 approximately, but it will be even less because energy factors are for new water heaters in perfect operating order under ideal conditions.
3) Energy factor is a measure of how efficiently the water heater turns energy BTUs into hot water.
Gas water heaters have higher energy factor because gas burner has more BTU punch than electric element, and can heat water faster.
4) However, energy factor is not measure of actual cost. It is merely a way to compare giant water heaters with smaller heaters, and gas with electric, without considering cost of heater, installation cost, repair costs, parts costs, life expectation of unit, disposal/recycling cost, or replacement cost.
5) You can improve your true energy factor by buying small cheap heater and maintaining it yourself so it lasts many years beyond manufacturer's warranty.
http://waterheatertimer.org/Replace-anode-rod.html
6) If someone buys a bigger water heater because it has better energy factor, it will not pay back the higher purchase cost. Same size to same size, the difference with higher energy factor is a few dollars per year.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
7) If you have sediment inside of tank, the energy factor is out the window.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 02, 2011 | Reliance Water Heaters
Hot water heater is constantly runnin and sds like water is running. the noise seems to be coming from the emergency valve area. there is water pooling around the bottom of the heater
Open following link to identify specific leak and remedy:
http://waterheatertimer.org/Water-heater-is-leaking.html
If TP valve is leaking: replace TP valve:
http://waterheatertimer.org/How-to-replace-TP-valve.html
If tank is rusted and ready to rupture, then turn water heater off:
Over next days, turn water heater on for short periods to make hot water when needed, then replace water heater.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Mar 19, 2011 | RELIANCE ELECTRIC WATER HEATER
I have a reliance 501 propane gas water heater how do i change a thermostate
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
8. Relight pilot light and check operation.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Feb 23, 2011 | RELIANCE ELECTRIC WATER HEATER
The pilot light went out on our Reliance 501 water heater.....no hot water. We replaced the thermol coupler (sp) and re llit the pilot. We got some hot water, but only one tank ful. We then replaaced...
The paid answerers might have a specialist in your model of water heater.
As a free answerer, I specialize in providing resources that might help you for free.
When you say the gas control pieces, I assume you mean you replaced your entire gas valve with a generic dial-type gas valve.
You replaced thermocouple, but you did not replace burner assembly that includes the pilot tube.
Your other gas appliances are working fine.
You have not installed a new gas furnace with a blower that is vented up the same chimney as the water heater.
You have put your hand near the vent hood to see if there is backflow coming into the water heater when the furnace turns on.
You have removed the vent hood to give you access to the vent pipe, and you lit a match and the smoke from that match drafted upwards. You have done the lighted-match test when the furnace turns on which reveals the general condition of the venting stack.
You have checked your outdoor vent stack to make sure there is no obstruction, or the vent hood is not missing.
The burner flame on the water heater is a clear blue color with very little yellow. This shows the quality of the combustion air and reveals if amount of gas flowing to burner is restricted.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Reliance is an AO Smith company
The site doesn't have a manual for the 501
I e-mailed Reliance several weeks ago asking for a 501 manual.
They send a generic gas water heater manual with no troubleshooting
http://www.reliancewaterheaters.com/lit/om/g616.html
Link above shows a typical Reliant heater, the 616
Age of your water heater can be seen on serial number.
The two numbers following first letter are the year water heater was made.
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Troubleshooting begins on pg 29
Troubleshoot flowchart begins on page 31
The new gas water heaters have the FVIR system so troubleshooting includes that information.
I don't think the 501 would have a FVIR flammable vapor prevention because it is older
The new systems have an igniter
The troubleshoot flowchart gives valuable information
Oct 29, 2010 | Reliance Water Heaters
Need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Jan 26, 2010 | RELIANCE ELECTRIC WATER HEATER
Reliance & Drain Valve for Gas Water Heater  Logo
205 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
