Zanussi washer FA 522 Filter and filter handle problem
Hi, I have a Zanussi washer 500rpm model FA 522. I live in Spain and our water is very hard. I use a calgon type product in every wash, but the calc build up in the filter is still really bad. I have removed the filter a few times (as the calc prevents the washer spinning properly after a few months) and it is always full of stone like calc. Now the filter handle has broken and the whole filter assembly can only be removed by prising it out with pliers. guessed it, the filter now leakes too due to the housing becoming distorted from the use of pliers. Can I buy a new filter housing, filter part and handle? Or is the washer doomed? (The washer is only 4 years old). Thanks. Linda.
  • 1462 Answers
SOURCE: Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Posted on Apr 15, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
  • 291 Answers
SOURCE: Kenmore 80 series top loading washer won't agitate and is noisy
Sounds like u may have broken the coupler gear between the motor and transmission... the replaced the belt with these gears on this model... But should go fill & pumb water out and NOT spin Or agitate... IF these gears or broke or stripped... heavy loads like u  said would do this... recheck and see if wash will pumb water out But will NOT agitate or spin.. IF so the above is your problem  and is Not to hard to repair  or much money
Below is a pic with the motor remove the white piece in the middle is 1/2 of the gear system with a rubber piece in the middle (not there)  and another like gear on the motor
sounds like these gears may be broken or stripped on your washer
Posted on Oct 27, 2007
  • 126 Answers
SOURCE: kenmore elite water filter
just leave your filter installed
Posted on Dec 11, 2007
  • 92 Answers
SOURCE: LG WM1814CW - Water/soap Leaking Under Washing Machine onto Floor
I suggest taking the top panel off (2 screws in back leave the plastic piece on the lid). push hard back and lift lid off. now you can look in from the top. look for soap residue to see if water is leaking down the side of the cabnet. if none is evident check hoses. what makes you so sure its in the middle/back. if you only notice it during the wash cycle you may have to go in back and take off the panel check around the bearing behind the pulley in the tub, could be leaking
Posted on Feb 10, 2008
I have a Zanussi 1200 fj 1254 when I turn on the machine and it starts to fill with water...water starts to pour out of the fluff filter mechanism never mind how tight we try to do it up ... any ideas ??
I suspect there is either limescale in the thread of the filter plug OR behind the filter itself and this is stopping the plug from being screwed home completely. Remove the plug, pull out the filter, clean filter compartment all round, especially at the back AND ensure the plug thread is completely free of limescale ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 09, 2011 | Zanussi FJ1254W Front Load Washer
Hi, I have the Zanussi Electrolux model. The door
'E20' for Zanussi washers means 'draining' problem.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
John C
May 11, 2011 | Zanussi FJS1225W Front Load Washer
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Simple in most cases its just the filter outlet has become full of day to day junk, debris and slime.
Slowly release the water by turning the handle to release the water. Ensure power is off.
Once the water has been drained into a shallow tray you can open the door.
Once the drum is empty, unscrew the handle completely to remove filter housing and clean out thoroughly.
replace and tighten up.
Turn on power and reset all programs.
This should work, Will take about 15 minutesto do, If it doesn't work, then it may be your pump. Also, check your long drain to see if there's anything clogging it up, rubberbands, hair bands coins, sock, etc.....hope this works for you....
Jan 09, 2010 | Zanussi ZWF1440 Front Load Washer
Hi, My zanussi washing machine model z221w does not seem to be draining properly - any ideas? Also I want to check the filter at the bottom rhs of the machine but I cant seem to open it can you help? A...
If you have located the filter at bottom right front of washer, firmly grasp filter handle, and turn anti-clockwise to remove and clean. if it does not come out, then something is jammed in filter, so just keep trying to pull it out.
Please rate my solution.
Nov 06, 2009 | Washing Machines
Zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
Jun 15, 2009 | Zanussi F1245W Front Load Washer
Zanussi zwf 1432 front loader
check the filter down on the right and cleane it
May 28, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
148 people viewed this question
Top Washing Machines Experts
