Question about Sport & Outdoor - Others
I am Recieving an error code of " SYSTEM COMM TWO WIRE" ... How do I correct this problem?
  • 3 more comments
  • david8367 Oct 03, 2009
    Life Fitness 97Te Treadmill
    Any luck with the Life Fitness 97Te Treadmill error problem?
    How to correct the following
    Error Code " System comm two wire "
    Thank You
    I have a Life Fitness 97Te Treadmill which is giving me an error of "SYSTEM COMM TWO WIRE" . Does anyone know what I need to do to correct this Error Code? LifeFitness Treadmill 97Te
  • david8367 Oct 04, 2009
    LIFE FITNESS 97Te TREADMILL
    THIS IS A TREADMILL !!!! NOT A TRUCK... LIFE FITNESS IS THE MANUFACTURER AND THE MODEL IS THE 97Te ... ERROR MESSAGE IS " SYSTEM COMM TWO WIRE "
    Guru:
  • 1,326 Answers
For what type of device??
Posted on Oct 04, 2009
  • 3,230 Answers
Please tell me the make model number??
Thanks
Posted on Oct 03, 2009
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Oct 02, 2016 | Bowflex TreadClimber TC5500
Please, how can I solve the fault code 19, Master COMM. On my Electrolux W4240H washing machine. All the engineer u contacted didn't get it. Please, help.
Error code 19, MASTER COMM.
Communication with superior system has been broken. The cause can be an error in the network connections, damaged cable, defective monitoring system, etc.
Action: • Contact the supplier of the monitoring system for possible causes of the monitoring system not communicating.
Dado
Aug 20, 2015 | Electrolux Washing Machines
4250N
Action:
Dado
Jan 07, 2014 | Electrolux Washing Machines
Tachometer not working correctly - reads low
what engine, what transmission? ok ,no one ever knows....
gas, not diesel
tacho.read low, compared to what>? you have a hand held
optical tach? like me? or is this post just a post
saying why is my engine idling way below 800.
or why is my slushpump A/T stuck in 4th gear.?
ever scan the PCM? do so, or miss the boat (i promise)
lets say the tach reads, 2000 but my opto scan shows 3000.
the cluster brain gets tacho data , via a data buss (CAN) from the
PCM brain, so scan the PCM for errors
it can be 3 things.
1: bad tacho.
2: bad PCM , no way
3: bad comm buss. if you see scanned DTC errors for the comm buss fix that first.
Also the PCM , you connect any scan tool made to the 16pin DLC
and see live RPM, it its correct? and no comm errors?
then the I/P cluster brain is bad or gauge. (or scrambled)
id reset the cluster head power. the fsm covers this.
its the memory wire. to the head.
but resetting things can be dicey. if not done right.
The PCM will report all RPM errros.
the FSM is here. buggy it is...
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
id check all fuses.
id scan it
if head lies. and PCM scan shows good.RPM
id then reset the head, the fuse are OID named, (hot all time)
do you have your glove box , operators guide.
in mine on page 400 is the fuse box. see that.?
mine has 2, m13 fuse is mine. ill look yours up. now
ok its fuse #17 (IOD) IOD means ign. off, draw (old school hot all time) F17 is 10amps.
do not pull fuses in a random way
or ever pull the battery cables.
or you might find bad happens, lost radio codes and other issues
even security system goes nuts.
Aug 29, 2013 | 2004 Jeep Grand Cherokee
My dodge journeys cd player say
My cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix thisMy cd player says MECH COMM ERROR, how can i fix this
Jan 03, 2012 | 2010 Dodge Journey
I have error codes flashing on my thermostat..it is an american standard model the manual for the therm. has ACOT900AC43UA on front..says to find addedum 18-HD32D2-1/69-2009 for codes i cannot find it...
Error codes from American Standard Pub 18-HD32D2-8, which is a one-sheet document that came with my American Standard air-conditioner:
29 = not listed
129 = not listed
80 = HPCO Fault - problem is in outdoor unit - Desscription: High Pressure Monitor Fault (hard lock out, cycle power to reset)
91 = Communication Inactive Fault - problem is in air handler - Descriptions - COMM Bit Master Clock Error, COMM Heat/Cool Demand Error, Serial Motor Communication Inactive Error
91 = Communication Fault - problem is in furnace - Descriptions: Blower motor no COMM response, Inducer motor no COMM response, Loss of heat/cool demand, Loss of clock signal
91 = Communication Fault - problem is in outdoor unit - Descriptions: Loss of Heat/Cool Demand Message (COMM), Loss of Bit Master (Clock Signal)
91 = Communication Fault - Description: Comm line is dead and no bits have been received.
By the way, I do not recommend American Standard. I've had mine 14 months and it just blew up - the entire control panel blew. My advice to you - think about a different brand.
Nancy
Scottsdale, Arizona
Aug 22, 2010 | American Standard Heating & Cooling
I am recieving a comm.error when faxingit also shows memory full when the page prints
Hi
You usually get a Comm error due to poor performance of your phone line. Check for any visible issues with the phone line. Check whether the jack is plugged in properly and the wire is not cut.
If you are sharing the phone line then check that any other devices are not interferrring in device's performance. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
There may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Daniel Scott
Jun 26, 2010 | Brother MFC-8460N All-In-One Printer
Canon Fax L100 has Comm Error. Seems to re-appear often. Presently not recieving faxes. Please help!
evry time press red button to clear it. It means that there are interferences in send or recive. Check your tel. lines.
Oct 09, 2009 | Canon FAX-L100 Plain Paper Laser Fax
ERROR MESSAGES
nthemba- all the error codes you see indicates phone line condition or error at reciving fax's end. For more details you can refer to
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02549&lc=en&dlc=en&cc=us&product=79477&rule=17804&lang=en
Sep 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Sport & Outdoor - Others Logo
109 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
