Question about Nintendo Wii Console
Wii wireless I have a wireless connection for my laptop and am trying to setup my new Wii but can't seem to get the right code# or something. Can anyone help?
  • Anonymous Dec 10, 2008
    same problem. keep getting error code, 51030 ?.
  • 556 Answers
Have you seen this page and the process? Could you try this and let me know where you have problems. I believe you should start with the Setting Up Your Internet section.
http://www.nintendo.com/consumer/systems/wii/en_na/online.jsp
Leave a comment here when you have an issue and I will attempt to help sort it out.
Posted on Dec 21, 2007
I have the same problem. unable to connect to my laptop.
keep getting connection failed error code 51030
Posted on Dec 10, 2008
HOW TO I GET MY WII TO CONNECT TO THE INTERNET
1.Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
2.Select "Wii Settings" to access the "Wii System Settings" menu.
3.Using the arrow on the right side of the screen, scroll to page two and select "Internet."
4.Select "Connection Settings."
5.Select "Connection 1: None."
  • If you do not have an empty connection slot, you will need to clear a slot.
6.Click on "Wireless Connection," then click "Search for an Access Point."
  • If using a wired Internet connection,
7.Select "OK." The Wii will display all the wireless networks it finds.
8.Select the wireless network that is yours.(If you're not sure which is yours, or you don't see any wireless networks)
Asked to enter a security key?
  • If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  • If you need to switch between upper and lower-case letters, or numbers and symbols, select the "Shift" key on the on-screen keyboard.
  • Ensure you review the security type in the top-left corner as well. If this is not the same security type that is used by your router, select "Change Security Settings" and select the appropriate security type.
9.Select "OK" 3 times to save your settings and start an Internet connection test.
  • The Wii console will run a connection test with your wireless network.
  • When the test is completed, you should see the following screen:
  • If the connection test succeeds, then your Wii is now connected to the internet.
  • The connection test was not successful, you will receive an error code.
    • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step eight (8) above for more information.
Don't know your routers security key?
Here's some:- A..To login into your Linksys router:
  1. go on this link: http://192.168.1.1
  2. The default username is: (leave blank)
  3. The default password is: admin
  4. Look for the security key settings. For Linksys routers, they are usually in "Wireless Security" on the "Wireless" tab or something similar.
  5. Find the selected WEP or WPA key, and write it down. Enter this number into the Wii or Nintendo DS when prompted.
B. To login into your Netgear router:
  1. Go on this link: http://192.168.0.1
  2. The default username is: admin
  3. The default password is: password
  4. Look for the security key settings. For Netgear routers, they are usually in "Wireless Settings" on the "Setup" tab or something similar.
.C.To login into your DLink router:
  3. The default password is: (leave blank)
  4. Look for the security key settings. For DLink routers, they are usually in "Wireless" on the "Home" tab or something similar.
Aug 18, 2017 | Internet Computers & Internet
Error code on my wii
Error Code 50300, 50301, 50302 It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following: Change your wireless router's channel to 1 or 11 Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab. Where is your wireless router located? Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference. Look for other devices Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Apr 09, 2015 | Nintendo Wii Console
Is there a fix to wii error code 50300 ?
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
If the problem persists, try our general troubleshooting for tips.
If you are still getting this error code, please call 1-800-255-3700 for further assistance.
For more help visit cbrtechsolutions
Mar 27, 2012 | Belkin Surf N300 Wireless N Router
Help, Im trying connectmy wii to the wireless internet and I keep getting a error code number 50300
Error Code: 50300 The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
  • It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
  • While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
  • If you are still getting this error code, please call 1-800-255-3700 for further assistance.
May 21, 2011 | Nintendo Video Game Consoles & Games
Trying to connect the wi to netflix the sid code goes in or is it a password
the ssid is the name of your wireless network, click the wii button in the bottom left of your main screen on the wii then click on wii settings , press the right arrow middle right of screen and go to the page that says internet. Follow the instructions on screen to connect to your network. then setup netflix and it will work
Mar 20, 2011 | Nintendo Wii Console
I have internet and my wii will not connect to it. I'm try to get netflix
Do you have a wireless setup at home? If you do then you have to setup the Wii to pickup your wireless network for you to get it to work. If you don't have wireless network then you can hardwire the wii from the modem, or you can buy a wireless router to setup a wireless network.
Feb 25, 2011 | Computers & Internet
I can't get my wii on line it keeps coming up with error code 50300 or 50200
  • It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings. Click here for help.
  • While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option. Click here for help.
  • If the problem persists, try our general troubleshooting for tips.
Error Code: 50200 Specific Error Code Not Found - General Troubleshooting
  • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available).
  • Check your router's broadcast settings to find out if it is set to "G", "B", or "Mixed." Mixed typically works best, but try all three to see if it improves the network connection to the Wii console.
  • Make sure that any other interfering devices, such as microwaves and cordless phones, are turned off. Wireless keyboards and mice may also cause interference.
If you are still receiving this error code, please click here for assistance.
Aug 10, 2010 | Nintendo Wii Console
Trying to connect my wii to internet but getting error code 32007 how can i fix
Error Code: 32007 There was a problem downloading the latest Wii update.
Please check the following:
  1. Our servers may be down temporarily or experiencing a high amount of network traffic, especially after a new update has become available. Wait a few hours and try again. If you are still receiving this error after waiting, check the next steps.
  2. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  2. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
May 09, 2010 | Nintendo Wii Console
I get error code 52131 on my wireless conection
Error Code: 52131 There appears to be an issue with your wireless router's firewall.
  1. Make sure your router is not listed on our "known incompatible routers" page, by clicking here.
  2. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
    4. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  3. Disabling your router's wireless security may help the Wii console's online connection. Consult your wireless router's manual or check with the router manufacturer for more details. Please note Nintendo provides these recom mendations as a resource to our consumers; it is up to each consumer to determine if adjusting their router's security settings are the right choice for their home network.
  4. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
Oct 14, 2009 | Nintendo Wii Console
Wii Wi-fi Internet Connection
A Wii has a macc address just like any other networked element. Do you have mac-address filtering turned on? If so, you may have forgotten to enter your Wii mac address in the list.
Hope this fixes your problem!
Jan 03, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
241 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
