Question about Microsoft Windows XP Home Edition
I get unknown error code 4260 when trying to burn cd
I get unknown error code 4260 when trying to burn a cd with itunes...I have windows xp and never had problems before
    Novelist:
  • 116 Answers
This is a disk error issue make sure if on windows you have the drivers for your CD drive(start>right click computer>click device manager) and also try an different make of blank disk.
TDK maxel and sony disks are notoriously bad on burning..
verbatin and imation disks burn without this error, stick to CD-R or CD+R disks the re-writables are notrious for not writing properly
this may solve your problem hope it helps
Posted on Oct 26, 2009
Just recently, when i try to burn a CD in itunes, it starts burning the first song, then cancels and pops up with "an unknown error occured (4900)" Then, it freezes itunes until i manually eject...
http://www.pc-library.com/errors/error-code/4900-0x1324/ theres your answer please rate me 4 thumbs up for doing the research for you. I hope this explains everything! Have a wonderful day.
May 10, 2011 | Gateway GT5220 PC Desktop
When I try to burn a cd on itunes I get the 4260 or 4265 error. I tried using another burner program but still wouldn't work
Could be disk error (just make sure if on windows you have the drivers for your CD drive: start>right click computer>click device manager), try a different brand of blank disks.
Use CD-R or CD+R disks, check your CDROM to see which is compatible..
May 05, 2011 | Computers & Internet
Im trying to burn a cd on itunes but i get error 4260. what can i do to fix it?
you can try to re-install/update to the newest version of ITunes. make sure the settings in BIOS are correct. drivers are up to date. use a different prog to burn to cd. there are alot of free progs that will burn to dvd/cd. like here : http://alternativeto.net/software/?profile=windows
Sep 03, 2010 | Microsoft Windows XP Home Edition
Trying to burn a playlist from my itunes account and get 4261 error message, what does this mean?
The ITunes error 4261 appears when attempting to burn CD's. The error code can appear for several reasons, including a faulty CD-RW, used CD's or a slow speed burner.
The error may also occur when you are trying to burn a file that has Dynamic Random Memory from ITunes & you have exceeded your permitted attempts.
The error can also happen if you are accessing the files from a different PC than where it was registered.
Try slowing your burn speed to 16x or even 12x or use Nero Express or Windows Media Player to burn your MP3 files. Other techniques for resolving this error include using new CD's & activating DLA in the Drive Properties.
I truly hope that one of these solutions clearly resolves your problem. Good luck.
Kindest regards,
Ste
Apr 01, 2010 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Cd burning
Usually when you get a 4300 error when you are writing to a disk it means one of two things.
1. The communication from the motherboard to the cd-rom is bad. Meaning a bad or loose cable connected to the cd-rom drive.
or
2. You have another cd-rom drive installed or another IDE device installed in your PC and they are both set up on Master or Slave and the operating system is having an issue sending the data to the right device.
If neither of these are YOUR issue, then I would take the CD-ROM drive out and check it on a friends/family member's pc to make sure it's not the drive itself.
Dec 13, 2009 | Microsoft Windows XP Home Edition
Burning a disc
please 1st you install a burning software and then burn you disc.
Aug 11, 2009 | Apple iTunes
I keep getting cancelled CD burns off of iTunes and Windows Media
I had that error befor I was burning with Memorex's 52x CD-R... when I switched to a Maxell's CD-R, the error was gone! And I left the burn speed at 'maximum'. It did it in about 4minutes. Good luck!
Dec 26, 2008 | Computers & Internet
Unknown Error 4900 on i Tunes and Windows Vista
I accidently lock the ipod and i forget how to unlock
Jul 29, 2008 | Apple iPod nano
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Microsoft Windows XP Home Edition Logo
2,921 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
