Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Kitchen Gas range
My maytag gasrange ignition started lighting up automatically in all the four burners, without switching it on. The spark is coming in all the four burners continuously even though the it started burning.
  • Anonymous Mar 24, 2014
    Have a maytag MES5770AAW that burned the suface indicator lights, all four of them. What's the part number for this?
    Problem Solver:
  • 14 Answers
First of all- when you turn any ONE of the burner knobs to "ignite" all FOUR burners will spark/click. This is normal. If you're getting a spark from the ignitors when all knobs are set to "off" then you most likely either got some moisture into one or more of the switches below the knobs (sometimes they will dry out and be fine after a while, but I have seen them burn-up/melt/arc too) OR one or more of the switches is stuck/shorted. Good luck and hope this helps.
Unplug the range before working on it and don't attempt anything you're unfamiliar or uncomfortable with.
Posted on Dec 22, 2007
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My Maytag Gemini stove started igniting all the 4 burners randomly by itself without the gas being on. I hadn't used it all day it was not wet, I checked thoroughly and it wasn't dirty. They all kept...
You will need a new switch harness part#12002789 and spark module part#74007397.
1. You can gain access to the switch harness by unscrewing 2x screws on each of the burners
2. The remove old wire harness and replace with new
3. Follow the wire from the harness it will lead to the spark module now replace it
Good Luck
Dec 07, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
KitchenAid gas stove main burner igniter does not work when the control knob is turned to the ignite position; however when any one of the other burners control knob is turned to the ignite position, the...
Hi Cecchung,
I think I know it.
Modern cookers have semi automatic ignition. Behind every knob there is a hidden switch and the switches are wired in "parallel". That means, when one button is put in "sparkstand", all plugs will spark. At least it should be.
In the youtube movie you can see how these switches are in a string.
So I suppose that the switch behind the button for the main burner does not work.
Fortunately, you still can lit that burne r with the other buttons.
Look at the movie, may be you can fix it yourself.
Kind regards, Dik
Maytag Gas Stove Burner Won Light Spark Ignition Switch
Feb 04, 2018 | KitchenAid KGST307 Gas Kitchen Range
Burner igniters are going off (all four) when the gas is not being used....
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 06, 2010 | Maytag MER6772 Gemini Electric Kitchen...
My Maytag kitchen range left front burner does not ignite/clic
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Sep 05, 2010 | Maytag MGS5770 Gas Kitchen Range
Maytag MGR6775 Gas stove. One igniter not working.
Clean the burner with a wire brush around where the ignitor is. it needs a proper ground to ignite. When you turn the burner on do you hear a click click click? If so this should solve the problem.
Jan 04, 2009 | Maytag MGR6775 Stainless Steel Kitchen...
The dial on my maytag gas stove shorted out
sounds as if one of your spark switches ( mounted on the gas valve itself) has shorted out, repalce the switch assembly, comeswith all foure sp[ark switches, easy enoough for you to do
Nov 30, 2008 | Maytag MGR5765QDS Stainless Steel Gas...
Igniter stays on on all four burners all the time. Had to turn off breaker to stop. Started sparking all by itself with burner in the off position.
Usually this happens when water or some type of liquid gets on one or more of the igniter switches. Let it dry for 48 hours, turn the power back on and see if it keeps on clicking. If it does, one of the switches needs to be replaced. Not a very difficult job. Hope this helps, APP tech http://www.AppliancePartsPros.com
Aug 05, 2006 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag MER6772 Gemini Electric Kitchen Range Logo
223 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
