Question about Sony NWZ-E436F MP3 Player
Is there anything I can do to get better radio reception? So much static it's almost unbearable
    Problem Solver:
  • 18 Answers
Try walking around your house and maybe you'll get better reception
Posted on Feb 09, 2010
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
May 17, 2016 | Motorola MagOne BPR40 UHF 8-channel...
I have been getting static on my Bose radio. When I turn the cord that is in the radio to the plug on the floor, it stops being staticy. Should I get a new cord?
The reason that it stops getting static when you move the cord is because you are acting as an antenna. This has nothing to do with the cord. You should probably place the radio closer to a window so it can get better reception.
Jul 28, 2011 | Bose Wave Radio
The am radio is unclear with a lot of static. Can this be cleared up?
Try moving the unit to another area, sometimes certain parts of a room get better reception. You might also just live in an area with weak reception.
Mar 03, 2011 | Bose Wave Radio
Hi, I'm about 40 miles NW of Chicago and reception here is not great. I like to listen to AM radio. I usually use my speakers just to listen to CD's, but I decided to try my Acoustic Research receivers...
First make certain the CD player isn't on when the radio is on. CD players cause inteferance with radio's. Apart from that you will need a good aerial. If that doesn't improve it then it could be down to local conditions -hills, power lines etc, blocking the signal. Also check there's nothing around the house that might cause interferance to the signal.
Jul 14, 2010 | Audio Players & Recorders
Kenwood RV7030 audio-video stereo has static without antenna
OK I am going to suggest two aerials for you. I would also NOT use the old cable as it will cause a lot of problems. It is best to replace it with the stuff they use for satellite dishes (see image).
The FM aerial will pick up signals from all sides. The TV aerial should give high quality signals and output for at least 5 sets.
Apr 06, 2010 | Kenwood KR-V7080 Receiver
Dual xhd6425 Reception Problems
My XHD6425 seems to be very inconsistent... Sometimes I get okay reception, other times I get terrible reception (much worse than my original stock Ford radio). The reception problems are more noticeable on stations that are more than 30 miles away or so.
Perhaps oddest of all, I've sometimes had it bounce back and forth between two stations (like if you are driving and in the middle of nowhere, half way between two stations), even in areas where I know should be getting good reception on one station and had never heard of the other other station before.
If you've figured anything out, please let me know.
Jan 16, 2010 | Dual Electronics XHD6425 Car CD/ MP3...
On a hot day the radio reception will stay clear for only a few m
It is the overriding by intersteller priority dimensional language conversion filtering. Nothing to worry about, It can be easily defeated and modulated by tightening your removable Radio Antenae.:-) Good Luck_Ned_
Oct 19, 2009 | 2002 Volkswagen Jetta TDI
AM reception
Since there is no AM antenna input on this radio, you will have to get an AM proximity antenna. One that does not need to connect to the radio. At Bose they recommend the Terk AM Advantage proximity antenna. I think you can get it on Audiovox.com.
Jun 17, 2009 | Bose Wave Radio
Problems with static
We doubt there is anything wrong with the wiring in your radio. It has been our experience that after market window tint can cause static and poor reception in vehicles that have radio antennas built into the rear window. Removing the tint improves the radio reception but still leaves something to be desired, especially on AM.
May 15, 2008 | 2007 Mercedes-Benz C230 Sedan
AM reception/AM power problems
Don't take your radio to work. Get your work done , then go home and listen to it. You will get better reception in a res. area.
Oct 08, 2007 | RCA RP7887 High-Performance Super Radio
Sony NWZ-E436F MP3 Player Logo
51 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
