Question about Maha Group Maha PowerEx MH-C800S 2-Hour Eight Cell AA/AAA Smart Charger
Flashing "Done" I plug it in. It does what appears to be a self check. Then all 8 places start flashing "Done" very fast.
24 v ryobi battery won't charge
Minimum FAST charge is 2 hours if it has a fast charge setting. If not, 6 to 8 hours to charge fully. I leave mine on overnight so about 10 hours..
May 22, 2016 | Ryobi Drills
Secureilock error code 13 on 2007 ford expedition. I am having problems remote starting my expedition.
Securilock problem for your remote start? Check when you try to start it, if the security light is flashing fast it is probably the PATS (security system) bypass. To reprogram it you will need two keys. First insert the first one and turn it to the run position. When the security light shuts off insert the second key and turn it to run. Once the light has gone off the second time pull the key out and hit the start button on the remote start fob, this all has to be done in 10 seconds. The vehicle will start, shut it off and try it again. If it doesn't start look to see if the security light is flashing fast again if it is the bypass needs to be replaced. If the light isn't flashing fast and it still doesn't start it should be honking at you or flashing its lights, count these then look in your manual it will tell you what is wrong. If none of these work let me know and I will help you. You can also check out my profile I have a tip that is about remote starts.
Good Luck
Dec 26, 2010 | 2007 Ford Expedition EL XLT
Changed all 8 plugs on a 1998 expecition, then misfires started under load, none supposedly prior. changed all coils, reinspected plugs for damage,crackes etc-changed some again- no codes during first week...
The first thing I would check is, are any of the plug wires crossed. Your firing order should be 1 3 7 2 6 5 4 8, the cylinders are number front to back passenger side 1 2 3 4, drivers side 5 6 7 8.
Jul 15, 2010 | Ford Expedition Cars & Trucks
Flashing airbag light on 97 maxima. Car was in an accident, airbags deployed, replaced bags and controller why won't the light stay off
To manually check air bag codes, turn the key On and push the driver's door switch (at the bottom of the B-pillar) 5 times or more within 7 seconds of turning the key ON. Then watch the air bag light flashing codes. The air bag light will come ON for 3 seconds and then give fast flashes if there is a code. Count the fast flashes as the code. So the air bag light on for 3 seconds and then 8 flashes is a code 8 for the passenger air bag circuit. after counting code clear codes and see if they come back
Nov 22, 2009 | 1997 Nissan Maxima
Machine error 76 is appearing
Error 76 is a fuser error, you can try going in and out of service mode, press the following key combination all within 2 seconds " features or function , * , 2 , 8 , 6 , 4 , " if done fast enough the all the lights willl be flashing. Them exit out of service by pressing 99. If the error returns after startup the fuser will have to be replaced.
Oct 28, 2009 | Brother IntelliFAX 4100 Laser Fax
Kyocera Ecosys FS 920
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
YBC (/\)
Mar 24, 2009 | Kyocera FS-920 Laser Printer
Flashing maintenance required light
NEEDS AN OIL CHANGE. YOU CAN RESET IT YOUR SELF. HOLD IN THE "TRIP" BUTTON AND TURN THE KEY ON (DO NOT START IT) 5 DASHES APPEAR AND DISAPPEAR 1 AT A TIME THEN 5 "0"'S AND YOUR DONE. SOMETIMES THEY HAVE TO BE ON "TRIP A" BEFORE YOU START
Nov 17, 2008 | 2006 Toyota Tacoma
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
DONE
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
FAST BLINKING GREEN & WON'T POWER ON
I had exactly this problem. After plugging and unplugging it multiple times over several weeks (even plugging it in quickly after it was unplugged but with the green light still flashing as suggested here) all to no avail, it just started working on its own one day. It worked for a few weeks and then the problem re-appeared.
InFocus tech support recommended:
1. Check whether the lamp door is securely closed.
2. Check the color of the LED and the number of time it blinks. (For me, a very fast almost flickering flash)
3. Does the fan operate? (My fan would go on when plugged in)
4. Remove the lamp module, shake it gently and reseat the lamp module.
For me, these steps did not work. InFocus then recommended that I send it to ProjectorDoctor http://online.projectordoctor.com/, and it was diagnosed with a bad power supply. $395, but it is fully functional again. Good luck.........
Jul 24, 2008 | InFocus ScreenPlay 7200 Multimedia...
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
Maha Group Maha PowerEx MH-C800S 2-Hour Eight Cell AA/AAA Smart Charger Logo
160 people viewed this question
Top Maha Group Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Maha Group Electrical Supply Expert? Answer questions, earn points and help others
