Question about Maytag Neptune MDE5500AY Electric Dryer
What type of oil do u use one the dryer rollers
    Sniper:
  • 68 Answers
White lithium grease works great on rollers and idler pulleys. it is a high temp grease, and long lasting. Shane
Posted on Oct 04, 2009
Making a roaring noise when started. very noisy
Hi damaestrogk....
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers are in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me
Aug 18, 2011 | LG DLE2301 Electric Dryer
Dryer turns on but dont not turn inside
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
You will have to remove your drum.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Sep 19, 2010 | GE DBXR463GB Gas Dryer
Our DDE 5300 GBLAD dryer makes a rumbling, thunder-type noise after it's been drying clothes for awhile. What is wrong?
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them then you will need to replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
May 15, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer is squeeking. Ok to oil in hole on back?
no oil.there's a kit you can buy it's a belt rollers and pulley inside the kit,change them out and you should be fine,don't put any oil in there it will get on clothes
Apr 18, 2010 | Whirlpool WED5500S Electric Dryer
Very loud noise every time it starts spinning
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 11, 2009 | Frigidaire GLEQ2152ES Electric Dryer
I HAVE A INGLIS ELECTRIC DRYER MODEL # IES5000RQ WHEN I PRESS THE ON BUTTON YOU HEAR THE MOTOR BU IT DOESN'T SPIN OR HEAT
Sounds like your problem may be a broken belt.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 10, 2009 | Kenmore 63942 Dryer
Drum wont turn, how do i open up the dryer to replace the belt
Good luck,
I hope this helps
Oct 09, 2009 | Frigidaire Dryers
Very loud metal vibration coming from the dryer.
Your problem could be your drum rollers.
If you plan on trying to do the repair yourself, then you will need to unplug the dryer from the electric.
Check the idler arm with the pulley, sometimes wear will cause the noise you describe.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy.
Check your drum rollers for flat spots, if they have flat spots on them this will cause noise like a thumping type noise.
Good luck,
I hope this helps
Oct 06, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Oct 06, 2009 | Roper REX3614KW Electric Dryer
Making a screetching/ rubbing noise while on. still working but very noisy.
if whirlpool/kenmore remove front panel after lifting top belt idler may be "improved glide type" instead of roller type replace with roller type if roller type ck rear support rollers for wear and rough spindle do not oil wipe spindle clean with wd40 and reinstall rollers being they spin freely
May 04, 2008 | Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
247 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
