Question about Hayward Star Clear Plus 120 sq.ft. Cartridge In Ground Pool Filter System with Pump
Have a hayward c-750 star clear filter. Why would sand be coming through one of the jets when we initially turn it on.
  • 990 Answers
Hole in the filter cartridge or if it only happens after you clean the cartridge could just be heavy dirt falling into the pipeing when you pull the cartridge for cleaning. There is a drain plug on your filter base that you can pull to clean out the bottom of the tank and avoide this.
Posted on Oct 03, 2009
Every time I vacuum, dirty water comes in thru jets. Help
One of two things is happening, either the sand has worn smooth or the the multi-port valve has gone bad, sand only lasts 3 yrs max.
Jun 01, 2013 | Hayward SAND FILTER, PRO SERIES
I just finished cleaning my pool when I noticed debris around the area where my inground pool jets are. So I backwashed and vacuum that area. However, once in filter mode I noticed sand at the bottom of...
When sand comes back from the filter, that means that the device inside the filter that keeps the sand in has broken. In order to replace the item, all of the sand must be removed and the tubes must be removed and new ones installed. Go to your local pool supply house with your filter information and they can show you how to remove your old units and they will sell you new ones. You only have to replace the ones that are broken.
Gary
Aug 12, 2011 | Hayward SAND FILTER, PRO SERIES
Have a sand fikter pool is constantly dirty and green was great all summer cannit see sand coming thru jets water clear and checks good
You may need to change your sand in the filter, depending on it's age. You should have a qulified repairman check this for you and do the job if nessary.
Aug 08, 2011 | Hayward SAND FILTER, PRO SERIES
My Hayward S240 is only catching a small portion of the dead algae. I have replaced the media, the laterals are intact, and have added a filter enhancer. The spider gasket is good. I have lots of dead...
dead algae is made up of microscopic particles. Most sand filters have trouble filtering out particles that small. I would recommend using a flocculent that will force the particles to settle to the bottom, you can then set the multiport valve to the "waste" setting and vacuum as much of the debris as possible. You can use an additive like fiberclear to help the filter clear the water up quicker.
Aug 10, 2010 | Hayward SAND FILTER, PRO SERIES
I have a Hayward s200 sand filter. I run it all the time mainly for about 10-12 hrs a day and my water still doesn't clear up. People keep mentioning the filter isn't working properly. and i notice a...
There should be no air getting into the lines .. bleed the air out of the filter, see if there is air getting into the filter thru the pump, this will give you poor circulation . If you are loosing water , then you may have a leak in the return pipe ,, Sand is not usually orange .. but soil around the pipes may be if you are in the southwest
Jun 10, 2010 | Hayward SAND FILTER, PRO SERIES
I changed the sand and i can only vacuum about 2
Try consulting the owners manual for these pool filters. It will give you a lot of info in the settings that your filter needs to be on to do specific tasks. I really think that it will help you get this straightened out.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
I have a hayward s200 sand filter. When I vacuum, i backwash but dirty water doesnt seem to backwash out, just clean water. When I turn filter on small amounts of dirt you cant see come out of jets and re...
Are you using the rinse setting for a few seconds following the backwash? If not, once you finish washing, stop the pump, change the valce to rinse, then run it about 3 to 5 seconds. Shut down then switch to filter and the particles should stop coming back to the pool.
Jul 05, 2009 | Hayward SAND FILTER, PRO SERIES
When vaccum dirt, comes back in thru jets. \have a hayward filter
Do you back-wash your filter regularly?
Sound like dirt build up.
Jun 29, 2009 | Hayward SAND FILTER, PRO SERIES
I have water dripping out of my above ground return jet. What could be the problem/solution?
If by jet you mean the port the pipe fitting threads into on the filter valve, remove the fitting, retape it with about 6 complete turns of a quality teflon tape, then coat the tape with a light coating of pipe dope to ensure the drop goes away.
If that does not relate to your problem, please clarify what you mean by jet with a picture of a sand filter.
Jun 14, 2009 | Hayward SAND FILTER, PRO SERIES
Sand is coming out of our Hayward filter and into the pool through the side return jets. How can we fix this?
One of the lateral fingers on the inside was cracked. Once we replaced this with a new one the problem ws solved.
Jun 10, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward Star Clear Plus 120 sq.ft. Cartridge In Ground Pool Filter System with Pump Logo
128 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
