Our tv was working and then the screen blacked out. It does not turn on again. What is the life expectancy of projection tv's? Any idea what type of repair this may require?
  • scgowler Oct 04, 2009
    The Model number is: HCN4226W / XAC
    Type# P55ACH428
    Do you need anything else?
  • ladywinn
    ladywinn May 11, 2010
    Please Post your brand Name and chassis/model number they will be on back of TV.
  • 5,138 Answers
So your TV is a samsung, Go to website Encompass Electronics order power supply board 1-800-638-3328
Posted on Oct 04, 2009
TV would shut off by itself and then several minutes later be able to be turned back on. A day later it shut off by itself, turned itself back on, shut its self off then a huge pop sound as purple and...
That tv is very old and it just reached its life expectancy. It could be repaired but it will cost you more than a brand new tv. Black Friday coming up and you will find a great deal.
Oct 29, 2013 | RCA HD52W59 HDTV Projection Television
Green light stays on, while the tv has black screen? and stays on for 2mins and than black screen come on, than 20secs later turns on again and this happens repeately
if its a rear projection it could be the light bulb is bad or blown. You can get ideas of what the lights mean at sony. If its the light don't buy one from Pure Glare. com They send out bad or blown bulbs.
Dec 08, 2011 | Sony Televison & Video
Screen black, lamp light is blinking Help,,,, is there a manual how to fix ?
The"LAMP"LED light indication is blinking or staying on.Mean ur tv projection lamp life is over.Require u to change a new tv projection lamp.Try website like Youtube.com type ur tv make and model and type in tv projection lamp replacement.There will have a tutoring video by some body teaching u how to do the replacement of the tv projection lamp.
Nov 18, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
We heard a pop last night the screen went black but we can still hear and the tv turns off and on
Most likely the loud pop that you heard was the lamp filament shattering and you can verify that by physically inspecting it,the UHP lamps have a life expectancy of 6000 to 8000 lamp hours when they are Phillips and from 3500 to 4500 lamp hours if it is an Osram,and you can find this items on discount-merchant.com or on Ebay
Please rate this answer if it was heplfull
Feb 18, 2010 | Toshiba 53AX62 53 in. Rear Projection...
Sony full definition lcd model 1080
Yes you have a bad lamp. Unfortunately, I have noted that many dealers either "forget" to tell the customer that the lamp will require replacement, or they overstate the expected life of the lamp. The usual life of a lamp, as stated by Sony is 4000 to 8000 hours. There are 3 factors that effect lamp life:
1) the number of times the TV is turned on and off. Every turn on works the lamp very hard, so to make the lamp last longer, limit the number of turn on/turn off cycles. My rule of thumb is this: If you will be back to the TV within 30 minutes, leave it on.
2) Proper ventilation. In general the TV should have at least 6 inches of space on all sides to properly cool.
3) Power loss. If you have frequent power outages, buy a small UPS for the TV. The TV requires a "cool-down" cycle where the fans run to properly cool the set. If the cooling cycle is interrupted, it can effect lamp life.
Replace the lamp with and original Sony lamp and vacuum any openings you can see that are dusty and you should be good to go. Be sure to rate this solution. Thanks!
Oct 30, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Plasma tv screen goes black once you turn it on. Only sound
I have a panasonic TH-42PX60U plasma TV. When I watch TV programing I have no problems, or with the DVD input. But if I switch to another input, be it video game (PS2) or vcr the screen sometimes goes black and the red power lcd light next to the power switch flashes. Holding the power button in for a few seconds will shut down the tv. Then I can turn it back on and it may operate normally again for a undetermined period of time, before the screen goes black again. This never happened when new. The tv is about 1 year old. Any ideas on this problem? Thanks Ernie
Aug 13, 2008 | Televison & Video
Toshiba 42pw33p rear projection tv
crt repair
http://www.riddledtv.com/repair/journal/Toshiba51H84/index.html
Jan 05, 2008 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
