Question about Russell Hobbs Kitchen Appliances - Others
I require a new cord fr an old coffe percolator. type cpi
Try these- i`m looking for a cord for same coffee maker http://www.toastercentral.com/cords.htm
Posted on Apr 21, 2010
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
My West Bend 3520 percolator does not heat enough to actually percolate. It heats water to about 80 deg and then stops. Power cord looks fine. Any thoughts?
the thermostat isn't holding long enough to get the desired heat any longer,, it needs replacement , the parts are hard to locate, and then you need to have it replaced, so I guess it depends on if you want that done, or just get a new 12 cup one at target for around 40 bucks http://www.target.com/p/West-Bend-12-cup-Coffee-Percolator/-/A-12408458 I tried searching for the part you need, But was unable to locate it
Sep 11, 2011 | Vacuums
My Mr.Coffe maker percolates, steams and gets real loud. Only about 1/2 of the water fileters down to make the coffee. The rest seems to turn to steam.
A bad thermostat and may be limed up causing the steaming problem.Could also have substantial lime on t-stat probe.
Jan 21, 2011 | Bloomfield 8543 Coffee Maker
Vintage Manning-Bowman Percolator fix-it guy says thermostat bad
Greetings,
I have an "Atomic" globe type art deco Manning Bowman percolator from 1947. It does not have a thermostat, just a fuse.
If your pot is blowing the fuse, are you using one with the correct amperage for the pot? This pot pulls 350 watts which works out to 3.18 amps. watts/volts=amps. You'd need a fuse that would allow the heating element to generate a minimum of 350 watts before blowung.
May 15, 2009 | Welbilt MR95TW Microwave Oven
Need electric cord for percolator coffee pot
You can find replacement cords for many counter top
appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the coffee maker with you to make sure you are getting the correct cord.
Apr 11, 2009 | Hamilton Beach Proctor-Silex Simply Coffee...
General Electric Electric Coffee Percolator
sure thing Fred
Try this
to order all of your part needs
http://www.abtecparts.com/Westbend_Percolators_51000.htm
Please don’t forget to rate me.
eric
Jan 17, 2009 | GE Coffee Makers & Espresso Machines
I need an electrical percolator cord
Thank you for replying to my e-mail.
To answer your question of how I fixed it, well, I cut the cord at the plug and worked very hard to undo the little connectors and put the wires back inside them and added a drop of solder to each stem. Works fine now. I could not find an electrical cord ANYWHERE! Aren't electric percolators manufactured anymore? I could not find an electric percolator. Mrs. Rosemary Lawson
Jan 02, 2009 | West Bend PERCOLATOR
GE percolator cord
Hi Joe,
I have the exact same problem. I just called 1-877-207-0923. You need to wait a long time for an operator. Provide the model number. The cord costs 12.99 with s/h. I've looked in all types of stores and cannot find a plug, so this may be our only choice.
We perked coffee lovers need to stick together
Happy New Year!!!
Ann
Oct 28, 2008 | Coffee Makers & Espresso Machines
Kitchen Appliances - Others Logo
188 people viewed this question
Top Russell Hobbs Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
