Question about Filter Queen Majestic Canister Vacuum
My Filter Queen just started making noise from the motor area, it was very hot. Upon removing the top thing that covers the area where the air blows out, there were sparks and it smelled pretty bad. My guess is the motor is shot. Is this difficult to change?
  • 430 Answers
The motor will need either a rebuild with new bearing, or replacement. Parts should be no more than $100 .EASY project. 20 minutes max fro a pro shop. If you can tie your shoes you can do this one yourself.
If replacing, upgrade to a ball/ ball ( double ball bearing) motor, same height, generally an AMTEK Lamb. A ball ball motor will give longer life
Under the cap you have removed are 3 screws.
You will detach them last. Note they are slightly offset in their pattern.
Open the vac as though changing the cone. Remove the plastic cone by undoing the center screw. Remove the inner filter disc and change . This should be changed every 6 months...
Now you will see three, screws or nuts in a triangle pattern. Detach them. Remove the rubber switch pedal from above .
.Now detach the upper 3 screws and the motor housing will lift off. Voila. Inspaect the cord inside and out for wear at it's socket. Now is the time to shorten if required.
There should be an insulating disc about the size of a coin between the motor top and the screen below the vac handle. You MUST reinstall on the new motor in case of a short in the vac.
Remove the foam or felt "muffler" and clean or replace.
Remove the wire nuts and note the wiring pattern for the switch, motor and power head. Note the motor position versus the cord. Mark with felt pen and reinstall the same.
Do not twist the wires when reinstalling, only twist the wire nuts. Check that they are tight and reinstall in opposite order.
Please post back if tehre is a problem or this helps
Posted on Oct 04, 2009
Testimonial: "Thank you so much!!!! Now I have to buy a motor."
Actually ours is a Princess II made by Filter Queen, purchased in 1987. Wondering if motor going bad because when switch on sometimes it starts fine but other times you have to push the switch several...
It sounds like it's probably the switch. It could also be loose wiring connection to the switch, which can result in sparking. This presents a fire and/or shock hazard. Don't use it until you get it repaired. I do recommend having the vacuum checked out for a definite diagnosis. You're right about it possibly needing a new motor.
Mar 30, 2011 | Filter Queen Majestic Canister Vacuum
How do I change the power cord on my Filter Queen vacuum cleaner?
First, remove the top filter cap. quarter turn.
Remove the three screws from under said cap.
The rubber switch cover will come off of the on/off switch pedal there. pull off and set aside.
undo the two clamps and remove the motor (chrome) section from the base.
give the handle a tug and the chrome cap should now come off and allow you access to the wiring and motor/switch.
optional side note: at this point you may want to replace the sponge filter around the motor too.
Remove the cord from the unit and rewire to the same spots the old cord comes out of.
reverse the instructions to put the machine back together.
Nov 05, 2010 | Filter Queen Majestic Canister Vacuum
My DC25 Animal is making a howling, whistling noise. Primarily when turning off (winding down to shut off)
if it started after you cleaned the filters, it is because when you smack the filter that is in the ball like they tell you to, it pushes the gasket in so air can sneak past it. take it back out and pull the rubber gasket away from the filter so there is about 1/16-1/8" away all the way around, then put it back in. it will seal it and stop.
May 13, 2010 | Dyson DC25 All Floors Bagless Upright...
I have two older Filter Queen (brown vacuum cleaners). Besides unclogging the hose area and making sure it is not filled with dirt, what else would cause the machine to run hot and have a high pitched...
High pitched sound is often caused by air leaks in air ducts. This will also cause hoover loosing sucking power and slightly overheating.
If the hoover is overheating a lot, then noise can also come from the motor. In that case the part must be rplaced.
Try replacing the cone filter, the secondary filter, and the insulation at the top of the machine.
If that does not fix the problem, then the hoover must be taken apart to clean or repair the air duct.
Nov 13, 2009 | Filter Queen Majestic Canister Vacuum
I need a wiring diagram & detailed specifications for my Filter Queen Majestic limited edition.
Open the vac by removing 3 screws below the handle area and the long screw at the bottom of the cone. If the motor has been removed, you will have 2 motor leads , 2 power head socket leads, and 2 switch leads as well as the cord. Do not twist your wires first when pairing, twist with the wire nut ony and tape afterword as there is metal nearby in the housing area
1 side of the cord goes to the switch only. The opposite side of the switch will go to 1 of each of the motor and Socket. The remaining motor and socket leads pair with the remaining cord lead.
While you are in there change the round filter dic covering the front of the motor and you could change the foam/ felt wrap around the inside of the housing.
There is a insulating disc at the top of the motor to prevent shock between motor and screen. Do not remove it.
Sep 07, 2009 | Filter Queen Majestic Canister Vacuum
FQ95x...motor gets very hot very fast
It sounds like you have a blockage either in your hose or the carpet sweeper. Try dropping a coin through the hose. If it comes out then check the sweeper.
Jul 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Filter queen 95X (1991) Motor is noisy but still work fine. Can there be a loose screw inside ? Can I open the motor and look inside ?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766802
Generic problem for all Vacuums
Posted by alexun on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The sounds coming from the motor sounds like it is the 2 sheet metal fans that do loosen up and start to make noise; and if you are handy and can do service work yourself you can replace the fans, but make sure you mark the wires when you remove the wire and the motor. If you have questions feel free to contact your local vacuum cleaner dealer in your area or cal the Filter Queen cust serv line listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.filterqueen.com/
Customer Service 1-800-344-1840
custserv@filterqueen.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
409 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
