Question about Whirlpool Ultimate Care II GSW9650LW Top Load Washer
How do i replace motor coupling on whirlpool washer
What is the capacity of this washer?
Posted on Apr 05, 2011
    President:
  • 1,304 Answers
Two screws on the control panel on the corners front or back
with those out roll the cove up and back
disconnect the lid switch clip on back wall
pop the two body clips with a screwdriver
pull off the cabinetpull the clips off the pump
pull the pump out of the way no need to disconnect
sam two clips on the motor
pull those off asnd drop the motor
the coupling goes betwen the motor and transmission
work backwards
youre done
Posted on Oct 05, 2009
How do I replace the motor coupling
Washer Motor Coupling (part #285753A) - How To Replace ...
? 8:35
https://www.youtube.com/watch?v=MYB5x-IqtIM
Aug 4, 2011 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace the drivemotor coupling on top load direct drive ...
Motor coupler replacing Whirlpool direct drive washer ...
? 5:08
https://www.youtube.com/watch?v=H0o95LEjBtM
May 22, 2011 - Uploaded by theapplianceman
For more videos visit my website at http://goo.gl/WdE9
Nov 23, 2015 | Washing Machines
I recently replaced the broken drive coupling on my whirlpool washer but it still won't agitate or spin. Could there be an electrical issue with the washer lid switch?
If it sound like the motor is running and you get no agitate or spin but it drains, and the couple is new, then you have a bad transmission. If the washer makes a hum like the motor is jamb, then look inside the pump. If the washer make's no sound at al after fill then the lid switch in normally the problem, but secondary problems could be faulty timer or motor.
Mar 26, 2015 | Whirlpool Washing Machines
Whirlpool ultra care ll, how to replace rubber coupling?
Flip control panel up, take off cabinet, remove pump off motor, remove motor, and your coupling is on the motor and gear case .
Dec 30, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool direct drive washer will not spin. the motor turns,it fills up,and it drains .it was loaded too heavy with towels and will not agitate or spin the mdel is whirlpool lxr9200hq1
The coupling needs to be replaced, it has broken in two pieces and cannot transfer power from the transmission. That part is around 25 bucks if you have a local appliance store, sears usually has to order them. But appliance repair shops usually keep them on hand, it's a common part..
Jan 05, 2011 | Whirlpool Washer Motor Coupling 285753A
Need to replace coupling between tub and motor? How does tub come off?
If you are referring to the motor coupling, it is actually located between the drive motor and teh gearcase. You DO NOT have to remove the wash tub in order to access and replace it. The following link explains step-by-step how to replace a motor coupling on a Whirlpool top loader:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
If you have questions about this repair, or if the model washer you have differs from the one you listed this question under, please post back and let me know. I hope this helps you.
Apr 19, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top load washer does not spin. Does
Hi, the likely problem here is a bad coupling. Here are the directions for a bad coupling. Kenmore's, Whirlpool's and Ropers are direct drive machines this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like:
8fbd130.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chassis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be careful to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling.
If you have any other questions please feel free to comment. Mike
Dec 26, 2009 | Whirlpool Washing Machines
Washer will not spin
this machine doesnt use a belt, instead it uses a motor coupling part number 285753, yes easy to repair, search you tube for whirlpool washer motor coupling, easier to watch then try to explain.
Feb 15, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool untimate care II won't spin/agitate.......
Welcome gonecamping
Whirlpool/Kenmore- Weak Clutch Spring
If the clutch is slipping the spring is weak and must be replaced.
In the Whirlpool it could be this.
Or a door latch
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How to replace coupler
Edward You can find complete instructions here: http://www.askgene.com/2007/02/07/whirlpool-washer-direct-drive/how-to-replace-the-motor-drive-coupling-on-whirlpool-direct-drive-washer/ Gendos...post back
Feb 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II GSW9650LW Top Load Washer Logo
78 people viewed this question
Dan Webster
Dan Webster
Sal De
