Question about Ovens
The spring in the door of our Delonghi (EO-1258) convection toaster oven has broken one of its' hooks. I tried bending a new hook with the remaining straight end of wire. I opened up the side of the oven, but I can't find where it was originally affixed. Also, is this a standard spring that could be replaced from a hardware store?
  • 10,865 Answers
The only proper way to proceed is to replace both springs. I recommend that you order two new springs from Delonghi. here is their customer care website http://www.delonghiusa.com/index.php?texts&pid=3
this site has their toll free number, and tons of other information that you may want.
Posted on Oct 03, 2009
I have a kitchenaid convection oven with microwave F6 EO code
Your tring to fix an appliance that's 10 yrs. Old ! Replace is your answer
May 14, 2012 | GE JKP85 Electric Double Oven
My oven door wont close fully
You may have accidentally moved the clean door lock lever that hooks the door to the lock position.. You could try hooking a string on the lever and pulling it over to allow the door to close, then try unlocking the door on control board. Just a idea, does not sound broken, good luck....
Mar 14, 2010 | Ovens
The lower door does not close firmly. It seems like the spring load is weak. Is there a way to improve the spring tension? I have model CM302ZS (Microwave/convection oven on top and convection oven on...
There is no provision made for adjustment of springs,
I'm afraid the only solution is to replace both door springs.
Trust this helps solve your priblem.
Dec 21, 2009 | Thermador SC302T Electric Double Oven
Door doesn't close tightly and sometimes the light stays on. Can I tighten the springs?
One of both of the springs are probably off or broken. Slide it out and inspect the hinges and springs which are at the bottom of the door. The springs hook to the hinge and the base of the oven farther back. You may have to remove the side cover.
Nov 27, 2009 | Jenn-Air Ovens
Oven door spring is either broken or off its hook?
Open the oven door and look in the sides of the oven trim. Probably 4 screws.
Mar 10, 2009 | GE Profile JT912 Electric Single Oven
Lock for selfcleaning oven did not retract all the way
try setting the self clean letting it lock and then hitting the cancel button. usually take a min or to to see if it will retract itsself. the only other option would be to tap it lightly with a hammer so you can use the oven and replace the latch
Dec 07, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Ovens Logo
82 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
