Question about Xerox 5830 Copier
I picked up a 5830 copier and a paper jam is in the LCD I followed the instruction, and there is no paper caught into the area per the displayed area or in the paper path period. Code is D3-1 Do you have a solution.
  • 239 Answers
The machine has been sitting around for a while, or was just been stopped being used.
Try cleaning the brown roller in Tray 2.
Try the other paper trays see if they work. Tray 1 and tray 3.
We would need more information about the results of these areas and how it worked.
If there is alcohole, try cleaning the brown roller. The other rollers are harder to see. This machine could even have bad paper feed clutches.
A xerox serivce call would have to be placed to do the major repairs.
Posted on Oct 26, 2009
How to fix canon iR2016J copier paper jam with this orange light warning which does turns anytime the ''paper jam message appears on the LCD screen?
A warning for a paper jam will be displayed, when at least one of the sensors does not register the expected movement.
Could be caused by a paper that won't come out. Could be anywhere in the printer, but also by a dirty or defective sensor.
That is why a service engineer must know where all sensors are, to check them.
After removing the "jam" the printer must know something changed, By again a sensor noticing a door was opened and closed (to clear the jam in that area of the sensor) or by switching of an on again.
Please check the whole printer if all sensors are free and clean. Then switch of an on again. If nothing helps you should call a service centre close to you.
Jan 19, 2015 | Canon Office Equipment & Supplies
Paper jam error
did you try powering it down and unplugging it?
Sep 17, 2013 | HiTi P510L Photo Printer
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
My printer says I have paper jam, please remove. but i have only been able to remove partial pieces. How do I get at the rest left in a spot I can not reach
Here's a link from which you should be able to download the online manual with a troubleshooting section that includes specific instructions on clearing a paper jam. See also this page, as I have no great confidence in the links I get from canon, their website is so backwards. If you choose the service and support option, then ask "how do I clear a paper jam" you'll see the instructions they offer.
Issue: Paper is jammed inside the printer
Solution: Remove foreign object from paper feed area (MP130)
Remove foreign object from paper feed path If error message
  • [PLEASE CLEAR PAPER JAM AND PRESS [OK]] or
  • [CHECK PRINTER]
is displayed, follow this procedure to remove paper or obstructions from the machine. Clearing Jams In The Paper Output Tray:
  1. Gently pull any jammed paper out of the Paper Output Tray.
  2. Press .
  3. If you cannot see any jammed paper in the Paper Output Tray, remove it from the machine's interior.
    1. Press to power off the machine.
    2. Lift up the Scan Unit until it locks into place.
    3. Open the Paper Output Tray.
    4. Look in the print area for an obstruction (such as a paper clip, staple, tape, etc.) and then remove it.
  4. If you are printing from an application software, follow the instructions displayed on your computer.
Clearing Jams From The Auto Sheet Feeder:
  1. Gently pull out any jammed paper from the Auto Sheet Feeder.
  2. Press .
  3. If you are printing from an application software, follow the instructions displayed on your computer.
Sorry I can't offer you much more, but just try to get all the bits out. Sometimes a pointy tool on a vacuum will help. Otherwise, maybe you can wrap and tape a post-it note around a popsicle stick or something to reach the paper and try to coax it out, or maybe a bit of folded tape on the end of a ruler or something like that. Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 02, 2011 | Canon PIXMA MP130 All-In-One InkJet...
I HAVE A HP 4345 THAT HAVE A PAPER JAM ERROR. THERE IS NO PAPER JAM. HOW DO I FIX THE ERROR?
If safety is not caught up paper, paper pick rollers probably replace worn or cleaned rollers
Oct 19, 2010 | HP Office Equipment & Supplies
Paper jam
there must be a little paper left from a jam or there is too much paper in the tray
Jul 12, 2010 | Brother MFC 240C All-In-One InkJet Printer
Paper won't go through xerox
Under rubber roller of the presenting the paper is located brake platform. Check as she works. This often can be that paper pulls not exactly. Follows to restore the brake platform. Good luck.
Oct 07, 2009 | Xerox XC356 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
May 19, 2009 | HP Photosmart C7280 Printer
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
