Question about Konica Minolta DiALTA Di200 Copier
Toner just replaced toner and machine is still asking for toner. Machine has shut down
  • 146 Answers
Di200 [Subject] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good. [Description] "Please Add Toner" is displayed even though the toner bottle is full. The ATDC circuits have been checked and the main and sub hopper motors are good.
[Solution]
CAUSE: Inside the sub hopper, the magnet (P/N 9326-2900-06) may be catching on the inside of the hopper, preventing proper actuation of the Sub Hopper Toner Empty switch.
SOLUTION: Make sure that the actuator can move freely up and down when no toner is in the sub hopper.
Posted on Jan 03, 2008
AR5731 Undetected
Dear
The refill guy may done somthing which by pass the CRUM chip. At your end you may check the module attached to the toner cart.and test with alter that chip.
This may solve.
Before doing this pl.check the errorcode display .there might be other related problem with the machine.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
Minolta ep 6001 cf 0072
Sir/Mam,
open the front door and close it , wait a sec
Power off the machine
Take the toner bottle out!
power on the machine NO TONER BOTTLE IN IT
when the machine ask for toner put it in properly if the nub on the bottle is damage replace it that is how the bottle is turned bye the machine so ensure it is not damaged and install the correct bottle and correct TONER. The code is a problem with toner motor system.
Aug 09, 2014 | Konica Minolta Toner Cartridge Black 50000...
My machine minolta 4000 showing code c0700
DId you open close the front door. if that does not work then take the toner bottle out. turn of the machine then turn it back on with no toner bottle in the machine. let the machine do its thing the machine will then ask to replace the toner at that time install the toner if that does not wok you have a problem with the toner motor and associated circuitry.
Mar 23, 2014 | Konica Minolta Copy Toner, 40000 Page...
How to reset error sc 23- 1
Sir/Mam,
Mite want to remove the toner bottle, shut the machine off first then remove the bottle then turn it on with no bottle then replace the bottle when the machine is asking for it.
Dec 23, 2012 | Konica Minolta Dv601k 7165 Developer
Konica minolta 363 error message c2201
Toner bottle failure to turn. Shut off the machine remove the toner bottle, turn on the machine with the bottle inside it, wait for the machine go thru its paces when it ask for the toner install in correctly if the knub on the bottle is damage get a new one . if this does not work get a tech to look at it either the motor is bad or worse the control board is bad$$$
reset open close side door
Feb 24, 2012 | Minolta Office Equipment & Supplies
Copier turns on and doesn't stop running. Can't print or reset. It seams stuck in warmup.
This almost always means the toner cartridge is empty. This is especially true if you can hear sort of a thump noise about every 5 seconds or so. When these toner cartridges run out the machine will still try to add toner. If it does not get it, it will eventually shut down and turn on the red toner light which looks like a stack of 6 dots. Just turn the machine on and let it run. After a few minutes it will shut down and turn on the toner light. If not reply back.
Good Luck and Thank You for using Fixya.
Oct 17, 2010 | Sharp AL-1642CS Copier
How do you get the toner cartridge out
These cartridges have to be in the "home" position before removal/replacement. Just close the machine back up, turn it on and let it cycle. This may take several minutes if the machine is out of toner. Let it run unitil it COMPLETELY shuts down (quits running). The toner bottle will then be at it's home position and you should be able to remove it very easily.
Mar 04, 2010 | Minolta DiALTA Di183 Copier
Toner just replaced; asking to "reset" Broken Registration.
Turn machine off. Hold * and 1 and 3 down at the same time while turning machine on. This should reset "Broken Registration".
Sep 22, 2009 | Xerox Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
218 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
