Question about Poulan Pro " Pro" Self Propelled Mower
Mower runs fine till it's in the grass, it dies instantly
The mower will run fine while it's on the side walk, but when you push it into the grass it dies.i have checked and cleaned the plug, emptyed the gas and re-filled it with fresh gas, cleaned air filter, all to no sucess. it still dies.
I'm having the exact same problem any input would be much appreciated
Posted on Aug 27, 2012
  • 31 Answers
Too much oil too little oil.............check the blade some thing maybe raped around it
Posted on Oct 03, 2009
Craftsman riding mower back wheels not rolling, seem locked up, engine won't start. Clutch and levers still move freely. Was running fine last use. Not sure what is causing this
Grass always gets caught in mowers. THis may help.
Turn mower off, detach battery.
Turn mower on side.
Clean grass everywhere you can clean grass.
Right side mower.
Attach battery.
Start.
Does that help?
Jun 28, 2017 | Craftsman Garden
Tip
Personal Safety
Be sure to take the right safety precautions before you mow.
  • Never attempt to lift or repair mower with engine running.
  • When mowing with a walk-behind mower, wear heavy-duty shoes with non-slip soles and long pants to protect your legs.
  • Always wear eye protection when operating a mower.
  • Don't mow a wet lawn or late in the day when the light is dim.
  • Never let the starter robe snap back when starting mower.
  • Always mow up and down an incline with a traditional (i.e. unit with steering wheel) riding mower.
  • Always mow across an incline with a residential walk-behind mower.
  • Never adjust mower height, clean grass chute, or remove grass catcher with engine running.
  • Always stay clear of hot engine. Mufflers can reach up to 1,200 F (648 C
on Apr 02, 2011 | Garden
Why do grass get stuck in lawnmower than it starts to turn off
This can be happening from a couple of reasons, first if your grass is too damp this will happen with almost any mower, wait till the lawn dries out before cutting, you may be cutting the lawn when it is too high, try cutting it twice a week maybe this will help, you may try to raise the cut setting eliminating the amount of grass clippings that you have accumulated, if you are mulching or using the bag be sure the chute is clear, and lastly be sure you are running at a higher speed to push through the terrain.
Happy Mowing!!
Jul 14, 2010 | Mtd 22" Yard Machine Push Mower
Metro walk behind bogging down
the springs that control carby is there leaves or grass stopping it from moving ,some lawn mowers have bad desinge for air flow off ****
Jun 02, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Won't stay running
Check the gas cap vent. A partial vacuum in the tank will cause these symptoms.
Sep 06, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
May 23, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Poulan Pro " Pro" Self Propelled Mower Logo
315 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
