Rank: Apprentice
Rating: 71%, 4 votes
Enter this address into your web browser. Follow the instructions from Linksys.
-OR-
see below.
How do I access the access point’s web-based setup page?
Answer
A wired PC is a computer that you will directly connect to the access point via an Ethernet cable. The wired computer needs to have an Ethernet adapter to establish the connection to your access point.
If you’re accessing the web-based setup page of the access point, you need to do the following:
Connecting the PC to LAN Port of the Access Point
Assigning a Static IP address on your Wired Computer
Accessing the Access Point’s Web-based Setup page
Connecting the PC to the LAN Port of the Access Point
Follow the steps below to connect the PC to the LAN port of the Linksys access point.
Take an Ethernet cable and connect it to the computer. Take the other end of that same cable and connect it to LAN or Ethernet Port at the back of the access point.
Assigning a Static IP Address on your Wired Computer
To assign a static IP address on your computer, click
here.
Accessing the Access Point’s Web-Based Setup page
Step 1:Open a web browser such as
Internet Explorer.
Step 2:
Go to the
Address bar and enter your access point’s default
IP Address “192.168.1.245” and press
[Enter].
NOTE: If the IP address of the access point has been changed, type the access point’s IP address in the
Address bar instead.
The access point’s IP address can be changed by:
Running the access point s setup CD.
Changing it on the access point’s web-based setup page.
If you forgot the access point’s IP address you can:
Press the Reset button at the back of the access point for 30 seconds.
NOTE: This procedure will reset your access point to factory defaults. Any settings on the access point will be erased. The access point’s IP address will be “192.168.1.245” and the password will be “admin” after resetting.
Step 3:A new window will prompt for a
User name and
Password. Leave the
User name space blank, type in your access point’s password “admin” and click
OK.
NOTE: If the password of the access point has been changed, type the access point’s new password in the
Password bar instead.
The access point’s password can be changed by:
Running the access point’s setup CD.
Comments:
