Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic 53'1080i model pt53wx52cf green lines everywhere then turns off and blinks 3 times and will not turn on again unless i unplug it
    Top Expert:
  • Panasonic Master
  • 14,553 Answers
OK, three blinks is error code for short protection--considering you are describing a convergence problem what you have is one of the two STK-392-110 convergence chips is shorted.
The chips are about 2 1 /2 inches wide by 1 1/2 inches tall and are black in color. They are mounted on metal heat sinks with fins and are side by side--they will have the Stk-392-110 number printed on them in white letters.
If you locate them take a good look at all the light blue resistors in front of them--most are marked 2.2 ohms---look for any that are white or discolored in the middle---if you find one or more YOU HAVE FOUND YOUR PROBLEM.
BOTH chips and any bad resistors need to be replaced and the set adjusted. If you can do this repair you can save a lot of money as you can buy both chips (a pair) on Ebay for about 12 dollars plus shipping.
I have start to finish instructions for this repair on this type of set but I cannot post MY email here-NOT permitted to post MY email.
If you cannot do this repair yourself, shop around your area--most shops charge 300-400 for this kind of repair--I do them here for 200-250 and have done hundreds of them.
If they say it has to go to the shop--keep looking as any good tech can do this repair in your home in about 1 hour.
If you have any questions or need advice reply to this posting here OR check out all my many solutions here for more information concerning what I have told you.
I am here to help people.
Regards, SD TECH
Posted on Oct 03, 2009
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My panasonic pt-53tw53 wont turn on. The power light blinks 3 times then pause then three times....etc. If I unplug the set and plug it back in, it will work again but just for a short time, then shuts...
The 3 blink error is the convergence circuits need repair. The Panasonic repair kit PT53WX53 convergence repair kit is the correct kit for your model. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with instructions.
Sep 22, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-51hx42 model tv--When i push the power button the set turns on for a few seconds then turns off. it will not turn on again unless i unplug it and then plug it back in and then it again turns...
I have advice: DOES THE POWER LIGHT GO OFF AND THEN BLINK?
This set has a self check feature---the blinking power light should indicate what is wrong------a series of 3 blinks with a pause is short protection---common here.
A series of 5 Blinks means a short on the 140 volt line, more serious than 3 blinks but still fixable.
These sets all have a "SOS" SYSTEM---at least three protection circuits that will engage if something wrong and not allow the set to come on.
Let me know if a sequence of blinks---easy to miss if you do not know about it.
If this information helped you rate this solution as very helpful as I do this here for free.
If you have questions or need advice respond to this posting with a comment.
REGARDS, SD TECH
Aug 12, 2010 | Panasonic PT-51HX42 51" Rear Projection...
Panasonic PT-51HX41 51 inch
If the power led blinks its an error code such as 3 blinks means convergence failure which is the most common error for your model.Let me know the error code and I will assist you with what you need to do.
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I have a 53 inch wide screen Panasonic that is roughly 5 years old. It was working fine until I now hit the power button and the light stays on and then the picture comes on for 5 seconds then the TV...
whatsthe model number of your panasonic. Most panasonics mean convergence failure when the led blinks 3 times. Please respond to this post with your model number and I will post the correct ICs for your model and where you can get replacements with free instalation instructions
Jun 27, 2008 | Televison & Video
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
319 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
